RX8 Seatbelt Pretensioner Resistance
Old Oct 25, 2008 | 06:59 PM
Vitalogy80's Avatar
Hey All,
I'm rebuilding an RX8 after a crash where the airbags have deployed. The car is completely put back together and all the airbags have been installed and the airbag module was reset by a company in Texas.
The issue is now when I go to start the car, the air bag light comes on. This is because of the air bag/seatbelt tensioner that locks the seat belt in a crash. I've looked at ordering these from Mazda but they're over $250/each, so what I want to do is hook up a resistor into the circuit to basically bypass these seatbelt tensioners. I know this isn't recommended, but I have all the airbags installed and working and just want to get this car going.
Can anyone help me out and let me know what the resistance level is for the seatbelt tensioners.
Old Oct 27, 2008 | 08:49 PM
Vitalogy80's Avatar
Anyone have any ideas??
Old Oct 27, 2008 | 09:11 PM
62 ohms +/- .5 You owe me a beer
Old Oct 27, 2008 | 09:34 PM
tubingchamp's Avatar
What mawd bug?
Damn, Dan. What don't you know?
Old Oct 27, 2008 | 09:43 PM
I cheated...I have a spare in the garage
Old Jun 4, 2009 | 06:12 PM
blkhrt's Avatar
I'm having the same problem. could you please show me where to put the resistor? do you put the resistor on the pretensioner connector?
Old Jun 4, 2009 | 06:35 PM
You would have to put it between the contacts in the wire harness for the pre-tensioner unit.....there should be 2
Old Jun 5, 2009 | 05:41 AM
blkhrt's Avatar
so all I need to do is get a 62 Ohm resistor and put it between the 2 contacts for S1-10 connector that connecting to the pretensioner? am i getting it right? Thank you for your respond Dan.
Old Apr 5, 2018 | 01:58 AM
jamezy82's Avatar
Hi all. My RX8 was backed into near the rear passenger door. The door was replaced by the panel beaters and the seat belt was replaced by Mazda. but every time the back door is opened the seat belt jams and the door cannot be swung open far enough to get into the back seat.
Is this the same problem you guys are having with the seat belt pretension device you are talking about.
any information on this problem will be greatly appreciated.
Thankyou.
Old Apr 5, 2018 | 11:38 AM
StealthTL's Avatar
Metatron
No that's not a pretensioner problem.
I don't see how the belt can physically interfere with the door opening - can you post a pic?
thewatcher101
Aug 4, 2015 10:42 AM
Stubbs
Jul 28, 2015 09:23 PM
CMRine04
Jul 27, 2015 09:46 PM
Red Ryno
Jul 24, 2015 10:06 AM
