smoking!
Old Oct 25, 2008 | 10:51 AM
Big Money Pit's Avatar
smoking!
ok, this is my first rotary, and i think i'm just being paranoid...
my engine has about 17,000 miles on it, no catalytic converter.
i'm smoking a noticeable amount out of the exhaust on startup, until the engine warms up. after that, it levels off quite a bit. is this something i should worry about?
or am i just being paranoid?
there are no other problems with the car. i was lucky and got a pretty solid reman.
Old Oct 25, 2008 | 11:14 AM
sounds normal
Old Oct 25, 2008 | 11:40 AM
Go48's Avatar
When you say "...it levels off quite a bit." does it continue to smoke at a reduced level? A little smoke at startup is nothing for concern, but smoking after warmup is not normal.
Old Oct 25, 2008 | 11:44 AM
tdiddy's Avatar
Finally Boosted!!!!!!!
Also, what color is the smoke?
Old Oct 25, 2008 | 11:58 AM
lilring's Avatar
Finally a MT
it depends on how the smokeing is. if it is like this after 5 mins of start up then your engine is gone.. Look at this video. this is mine when the engine was toast
http://vids.myspace.com/index.cfm?fu...deoID=41560605
Old Oct 25, 2008 | 12:06 PM
tdiddy's Avatar
What did Mazda determine that smoking to be from?
Old Oct 25, 2008 | 04:39 PM
i took a quick look atfer i'd driven it around for a while, and i didn't see any smoke, but i just glanced at it.
the smoke is greyish... not too dark, not too white.
it doesn't do it quite as bad as it does in that video at startup. it runs great, it just smokes a little bit at startup.
Old Oct 25, 2008 | 06:15 PM
lilring's Avatar
Finally a MT
Mazda Found that the engine to have coolant entering into Rotor 2 and is loosing coolant through exhaust. That is what i just read off the report they gave me.
Old Oct 25, 2008 | 06:26 PM
05rex8's Avatar
sold the 8... :(
^you would think if that was the case you could smell burning coolant also?
Old Oct 25, 2008 | 07:35 PM
tdiddy's Avatar
That is the response I expected. Thanks!
Not when you are catless. All you smell/taste/see is unburnt fuel.
Old Oct 25, 2008 | 07:39 PM
05rex8's Avatar
sold the 8... :(
^haha, I love the smell of catless exhaust
Old Oct 25, 2008 | 09:45 PM
vX-2's Avatar
I think this is normal... I'm living in Nebraska and the weather here is cold in the morning, thus, whenever I start-up my car in the morning, I will always let it sit until the engine temp gets up. And in doing so, I've always noticed that some amount smoke will just come out and will be gone once the engine is up to temp (when little to no more smoke coming out from the exhaust, it also tells me that the engine temp is ready). And it'll always smell like rotten egg/ sulfurish also...
WranglerFan
May 31, 2022 07:51 AM
Luiss7
54
Aug 20, 2019 08:56 AM
WranglerFan
Nov 5, 2017 09:35 AM
pjwermuth
Sep 28, 2015 11:36 PM
Rx8_412
Sep 24, 2015 08:51 PM
