Rx8 NO POWER WONT START
Old Oct 25, 2008 | 02:24 AM
[PH47RX]'s Avatar
Hi guys
i've tryed seacrching but found nothing helpful ,
my car has been sitting the the garage with the bonnet up
and i went to start it today my car would not start
the car just made clicking noises and the gauges move up and down like defi gauges there are no lights on the dash only the immobilizer key and the power locking does not work what could be causeing this to my baby
what could be the problem , i dont drive the car much only for week ends and the car has only got 50,000kms
Old Oct 25, 2008 | 02:28 AM
Originally Posted by [PH47RX]
Hi guys
wow,
labrat had the same issue..
buy a new battery.. it is really that simple!
Old Oct 25, 2008 | 04:06 AM
[PH47RX]'s Avatar
i just brought a new battery abbout 6months back can it reallly b the battery..??
Old Oct 25, 2008 | 04:18 AM
StealthTL's Avatar
Metatron
Battery troubleshooting basics......
Did you leave the trunk open?
Interior light on?
iPod plugged in?
When you try to start, do the lights dim and go off?
Do you get one solid clunk from the starter, or multiple rapid clickettyclicks?
First thing is to heave on the battery terminals, by hand - do the clamps rotate at all?
S
Old Oct 25, 2008 | 04:59 AM
tsxmidship's Avatar
-you state that the car has been sitting....how long as it been sitting without you turning on the engine? any vehicle that sits for long periods of time will drain the battery enough to the point where the battery does not have enough juice to start it. try jump starting it.
Old Oct 25, 2008 | 05:16 AM
[PH47RX]'s Avatar
Interior light on?
iPod plugged in?
S
yeah its been sitting in the garge with the hood poped up , should a charge of the batttery fix this problem or should i taken off the terminals and put them on agian .??? thanks
Old Oct 25, 2008 | 05:29 AM
StealthTL's Avatar
Metatron
No point taking them off if they're tight, just charge it up, the slower the better.
S
Old Oct 25, 2008 | 05:51 AM
[PH47RX]'s Avatar
Thanks guys much appreciated
Old Oct 25, 2008 | 05:53 AM
StealthTL's Avatar
Metatron
Don't forget that after such a deep discharge, the steering will need to be reset.
S
Old Oct 25, 2008 | 08:56 AM
[PH47RX]'s Avatar
S
sorry what does this mean ?? What has to be done to fix this
Old Oct 25, 2008 | 09:14 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
This means that once you get your battery situation taken care of, you need to reset the DCS/TCS. To do this, turn the car to "on", but don't start it. Turn the wheel all the way to the right, then all the way to the left. Then turn the key to "off". Once that is done, it resets the DCS/TCS and you can start as normal. If you don't, then they will be "off" and you will have those two sysmbols light up on your dash. It will actually clear itself after a few drive cycles, but do the reset anyway. This will happen anytime you disconnect the battery.............or in your case..........loose connection or have the battery drain below a certain level.
Old Oct 25, 2008 | 12:26 PM
EDZRIDE's Avatar
2005 White GT
After you get it running, check the charging system too.
Old Oct 25, 2008 | 10:08 PM
believe it or not. the car knows the hood is open... it does drain power..
try to program a remote with the hood open..
as to the battery. try to charge it, it is a crap shoot..
Old Oct 26, 2008 | 12:41 AM
[PH47RX]'s Avatar
how would this be done thanks
Old Oct 26, 2008 | 09:16 AM
olddragger's Avatar
Swoope how does the open hood drain power?
Huh?
Whatyatalkingboutwillis.
OD
Old Oct 26, 2008 | 11:49 AM
EDZRIDE's Avatar
2005 White GT
After you get it running, put a voltmeter across the battery's + and - terminals, the voltmeter should show about 14.25 volts.
Old Oct 26, 2008 | 12:21 PM
hakuna matata!
Huh?
OD
the alarm wont arm otherwise i believe
Old Oct 26, 2008 | 06:01 PM
Huh?
OD
i dont know how much the the hood would drain power, it could be none, but i do know the ecu knows when the hood is open..
JakeKaminskisRacing
Aug 23, 2015 01:10 AM
Tyblat
9
Aug 6, 2015 10:43 AM
SIllver
Aug 1, 2015 07:34 PM
Ajmurphy85
Jul 30, 2015 07:51 AM
T_Mags
Jul 24, 2015 11:29 AM
