Storing the 8 for the winter.
Old Oct 24, 2008 | 02:51 PM
robel82's Avatar
Yippie ki yay
Whats the best way to store the 8 for the winter? Just throw in a garage and put a cover on it? I have a slow leak in one of the wheels so I was thinking put it on jacks and take them off. I know I would have to start her up every week just to keep the seals wet. Basically whats the best thing to do before, while, and bringing it out of storage?
Old Oct 24, 2008 | 02:54 PM
Renesis07's Avatar
Vtak just kicked in yo!!
Garage, wax it, fill the tank, put a fabric softener sheet in the cabin (keeps critters out), put little squares of carpet under all 4 wheels (prevent flat spots), put rags in the tailpipes to keep mice and crap out of them, disconnect the battery and put it in your carpeted closet, cover it.
Old Oct 24, 2008 | 02:55 PM
trickle charger on the battery if you've got it.
Old Oct 25, 2008 | 08:05 PM
04RX8man's Avatar
Rotary Powered Countryboy
last year (when i lived in PA) I just changed the oil, cleaned/waxed, car cover, rags in tailpipe and parked on ply wood (was parked in a dirt floor garage) and I started it about once a month just to keep the battery charged up and burn some fuel(oh and to get a little joy while it's snowing outside haha)
Old Oct 25, 2008 | 08:25 PM
invasion08's Avatar
Walmart sells a product the same as the battery tender but for much much less. It will keep your battery charged and will not over charge it. Fill the gas tank and had some Stabil to the gas tank and run the car for a few minutes. After the winter check the tire pressures, change the oil and filter and enjoy. I would also buy some BG44K fuel system cleaner and put that in before you bring the car back out. Just to clean the fuel system and clean up some carbon
Old Oct 27, 2008 | 01:42 PM
jp4wd's Avatar
The Big kahuna
It's about that time for me as well. i usualy just change the oil and filter. Detail the exterior and interior and over inflate the tires. Use a trickle charger for the battery and i try to start it once a week. If theres not much snow outside, i'll take it for a spin for a few blocks. That's why i dont like putting it up on a jack. I also reduce my coverage from full to liability from november to april since i wont be driving the car during those 6 months.
Old Oct 27, 2008 | 01:46 PM
robel82's Avatar
Yippie ki yay
Ok. Thanks for the replies guys.
Old Nov 11, 2008 | 09:28 AM
quazmosis's Avatar
Chode
Question: Why do we fill the gas tank full over winter? What does that do? What's wrong with half a tank?
Old Nov 11, 2008 | 09:39 AM
alnielsen's Avatar
It helps to keep the gas from separating and forming varnish that will clog the fuel system.
Old Nov 11, 2008 | 10:24 AM
Shinka_MJR's Avatar
SHKWAV
definitely add stabilizer to it as well to help get rid of the water. rust in the gas tank ftl...
Old Nov 11, 2008 | 10:55 AM
quazmosis's Avatar
Chode
Does it matter which stabilizer to get?
Old Nov 17, 2008 | 10:44 PM
Paul D's Avatar
Very hellpfull thread this is my first winter wiht the car, will prolly do the steps to store it
OnebaddRx8
Oct 17, 2015 10:05 PM
Quiggs321
Sep 30, 2015 05:34 PM
