SSV Valve Stuck Open? Greddy Turbo?
Old Oct 23, 2008 | 07:04 AM
RXTC's Avatar
Pistons EH!
Exclamation SSV Valve Stuck Open? Greddy Turbo?
I keep getting a CEL that reads SSV stuck open? whats this all about? I have a Greddy turbo kit, is there any relation between the two? Also getting CEL: RKE p0039?
Old Oct 25, 2008 | 11:15 AM
tdiddy's Avatar
Finally Boosted!!!!!!!
You are using the eManage Ultimate, right? If so, there is a resistor in the harness that keeps the valve from opening and there is a block off plate that prevents air from entering the ports. Its normal to get that code and can be fixed by removing the blocking plate and rewiring the harness so that the valve functions normally.
Old Oct 27, 2008 | 02:28 AM
joepatterson's Avatar
2004 VR 6 SPD
Can you tell me exactly where this resistor is? I'm getting that CEL code too, but I did not install the blocking plate. I did install the Ultimate ugrade computer though.
And why did GReddy do that? Why would you want to block that port?
Old Oct 27, 2008 | 08:30 AM
Cuz Greddy rush their kit.
Old Oct 27, 2008 | 10:30 AM
gregs's Avatar
Pull My Finger
so is that block off plate necessary for install? im running cobb ap
Old Oct 27, 2008 | 01:22 PM
MazdaManiac's Avatar
No. The plate is there because the air column collapses when it opens and the Mitsu turbo in the kit can't catch up because the WG can doesn't have enough authority to close the WG again.
This translates to a drop in boost at the 6k mark or so.
Old Oct 27, 2008 | 04:48 PM
gregs's Avatar
Pull My Finger
now i know what that plate is for, sounds like i need it then, thanks jeff
Old Oct 27, 2008 | 07:04 PM
05rex8's Avatar
sold the 8... :(
^I didn't bother installing the plate......why would you want a 4 port engine?
Old Oct 27, 2008 | 08:20 PM
gregs's Avatar
Pull My Finger
the way i read jeffs post it seems like its needed did i read the post wrong?
Old Oct 27, 2008 | 10:16 PM
05rex8's Avatar
sold the 8... :(
Jeff never used it. Neither did Mysql. It was basically Greddy's half *** solution
Old Oct 27, 2008 | 10:21 PM
05rex8's Avatar
sold the 8... :(
check this thread, post 373 and on to the next page:
https://www.rx8club.com/showthread.p...blocking+plate
Old Oct 27, 2008 | 10:43 PM
gregs's Avatar
Pull My Finger
thanks for the link...makes my install easier
Old Oct 29, 2008 | 02:41 PM
2004 VR 6 SPD
Blocking Plate
humm...
Time to get Jeff's upgraded turbo for the GReddy kit maybe.
But meanwhile, I can't figure if I should block it, or leave it off...and take the resistor that was mentioned out of the harness. If I only knew where it was.
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
yurcivicsux
192
Sep 12, 2017 10:54 PM
jDt!
Oct 2, 2015 04:04 PM
tgaffner
Sep 7, 2015 08:49 PM
