AEM install intake question
Old Oct 22, 2008 | 08:27 AM
Toxic Gecko's Avatar
AEM intke install question
I just picked up an 04 BB 6MT Touring. It already has an AEM intake installed. One of the three vacuum hoses keeps popping off. I can take care of that no problem, but I was wondering if it mattered which way they were hooked up. If it does I want to make sure they are hooked up correctly, just in case the dealer messed around with it or something.
Also I was wondering about the metal vacuum hose where the factory airbox was. It is a thin metal line attached to the floor of the factory airbox and leads toward the front of the car, does this just stay open or is it supposed to be capped or attached to something? If needed I can attach some pics later.
Thanks in advance for the help.
EDIT: Attached instructions from AEM's website.
Last edited by Toxic Gecko; Oct 30, 2008 at 08:26 AM. Reason: Added PDF installation instructions from AEM's website
Old Oct 22, 2008 | 08:59 AM
imput1234's Avatar
I ♥ Drifting!!!
buy a clip, put it on the hose to tighten it.
Old Oct 22, 2008 | 09:08 AM
Thanks for the reply, but as I siad, I already had that part taken care of.
I was curious about the connection order (if any) of the three hoses and if the small metal hose on the floor of the factory airbox needed to be capped or connected to something.
Thanks.
Old Oct 22, 2008 | 09:13 AM
mysql's Avatar
Doppelgänger
all 3 lead to the same intake tube, so order doesn't matter. the vfad actuator can be ignored since it's not hooked up to the intake manifold anymore. Most people uninstall it completely though, instead of leaving it in the car.
Old Oct 22, 2008 | 10:04 AM
That's what I thought on the first part, I wanted to be sure though.
The vfad actuator (i'm guessing this is the metal hose I spoke of) still has vacuum. I can feel and hear it if I put my finger over the end of it. I have attached a couple of pics for clarification.
If this is the correct part and can be removed, am I correct to assume there needs to be a cap where the hose will be disconnected from the IM.
Thanks.
Attached Thumbnails AEM install intake question-rx-8-vacuum-1-50%25.jpg   AEM install intake question-rx-8-vacuum-2-50%25.jpg
Old Oct 22, 2008 | 10:08 AM
malignant's Avatar
That might be the hose you have to cap, I vaguely remember capping one during my install...I'll check in a bit, I'm just lazing around right now haha.
Old Oct 22, 2008 | 10:13 AM
Sweet, thanks, I'll look forward to it.
Old Oct 22, 2008 | 02:31 PM
Jon316G's Avatar
Grasshopper
Yup!
If you don't have a vacuum cap handy, buy a pack at Autozone for a couple bucks!
Old Oct 22, 2008 | 03:17 PM
Done and done. Thanks for all the help everyone.
Old Oct 22, 2008 | 03:52 PM
kersh4w's Avatar
Hit & Run Magnet
you have to cap it? i just left it off.
i guess i could put a screw in it or something.
Old Oct 30, 2008 | 08:13 AM
In case anyone wants or needs the info, I added the installation instructions (PDF document) from AEM's website to the OP.
Thanks again for everyone's help.
jay_tibo
22
Sep 13, 2016 08:10 PM
GK1707
Dec 2, 2015 10:01 AM
poppinparker
Aug 10, 2015 09:20 AM
MolecularConcept
Aug 5, 2015 04:43 PM
MrORAN6E
Jul 24, 2015 09:32 AM
