Tail End Electrical Problems
Old Oct 20, 2008 | 10:10 PM
KWarner04's Avatar
Traveling Fool
I'm having a few issues with the electrical components on the tail end of my 8. For the longest time, I've always used the button next to the hood release to open the trunk. I tried to use the keyless trunk button the other day and it didn't work. So I tried the button on the car and it didn't work either. So right now, only the button in the car is the only way to open the trunk (or use the key).
Then last night, I realized my license plate light is out. I went to buy some new lights today and when I replaced them, the light still doesn't work.
I thought it might be a fuse, but after checking all the fuses, they are all good.
Any ideas on what to look for now? Thanks for the help!
Old Oct 22, 2008 | 09:22 PM
KWarner04's Avatar
Traveling Fool
Ok...anyone know where I can find a wiring diagram for all the electrical components in the back? Maybe I can figure out something from there.
Old Oct 22, 2008 | 09:23 PM
invasion08's Avatar
Check your fuses sounds like one is blown
Old Oct 22, 2008 | 09:51 PM
KWarner04's Avatar
Traveling Fool
Yeah...I went and checked the fuses again...all good. According to all the fuse diagrams I can find, all the tail lights (brake, tail, signal, license plate) are all on the same fuse. So it seems like if it was a fuse, all the lights on the back end would be out.
Thanks for the help though!
Old Oct 22, 2008 | 09:55 PM
Jon316G's Avatar
Grasshopper
Ask and you shall receive.
There is a 10A TAIL fuse just after the TNS relay.
Hope this helps.
Old Oct 22, 2008 | 09:56 PM
Jon316G's Avatar
Grasshopper
LOL... you posted before I could finish my post above!
Old Oct 22, 2008 | 10:13 PM
KWarner04's Avatar
Traveling Fool
Jon,
Thanks for the diagram. Looks like all the lights are on the same circuit, so it must be something with the connection on light since the rest of the lights come on.
As for the trunk not working, I'll have to mess with that later. But my idea that it was the same thing is wrong.
Old Oct 22, 2008 | 10:18 PM
u mean "some" thing is wrong.
I hope there is no short or cut in your wiring harness. Cuz it will be really painful to check it out.
the wire goes from the right side to the back of the car. so you might want to look into that.
Old Oct 24, 2008 | 04:35 PM
KWarner04's Avatar
Traveling Fool
Ok...finally got down in there and there was a connector that was disconnected. Sure enough, it solved both of my problems (the license plate light and remote trunk release.)
Thanks for all the help guys!
xAgyex
Jun 3, 2026 03:47 PM
GARCIAC951
Sep 10, 2015 07:17 PM
TJSiegrist
Sep 10, 2015 09:29 AM
superROB23
Sep 4, 2015 01:22 AM
Octomus
Sep 3, 2015 11:40 AM
