Idling Problem Help guys.
Old Oct 20, 2008 | 04:59 PM
mikeman's Avatar
OK today after 9 days of storing my rx8 i turned it on fired right up but i let it idle for like 3 minutes and than took it for a 100m drive i put it in neutral and let it idil while i sprayed water on i heard the engine revving up and down i looked inside the rpm was going to about 1k and than droping to 800rpm and after a while it stoped doing it
any one else notice this? is it normal?
Old Oct 20, 2008 | 05:05 PM
Marklar's Avatar
Idling between 800 and 1k seems normal to me. I know I've seen mine do that.
Old Oct 20, 2008 | 05:18 PM
That is normal. Also the stock tach is off by about 100rpm. Normal rotary, it took me a long time to get used to this.
Old Oct 20, 2008 | 05:33 PM
CyberPitz's Avatar
Huge hole is huge
Mine only does that on warmup. Otherwise it never hits 1k rpm's on full idle.
Old Oct 20, 2008 | 05:36 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah on warm up is fine when it's warm should sit anywhere between 800 to 1000 rpm
Old Oct 20, 2008 | 05:38 PM
quazmosis's Avatar
Chode
Shouldn't drop below 750 though. If so you may have a problem.
gwailo
May 14, 2024 06:57 AM
TJSiegrist
Sep 10, 2015 09:29 AM
ed0128
Sep 9, 2015 04:50 PM
Octomus
Sep 3, 2015 11:40 AM
