just ordered side lights
Old Oct 15, 2008 | 05:27 PM
ferg's Avatar
Smile just ordered side lights
anyone have any clue to install them?
Old Oct 15, 2008 | 05:30 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Yep............it's pretty simple really. One screw is a little tough to get to, also there is one small tab that you don't wanna break. Hang on a few and I'll see if there is a DIY on this, but you should go look in that DIY section as well.
Old Oct 15, 2008 | 05:34 PM
Mazurfer's Avatar
Alright.....here ya go...pictures and everything!
https://www.rx8club.com/showthread.p...ide+marker+DIY
This is just one of a couple DIY's that I found using "side marker DIY" in trhe advanced search function.
You better start using that "Advanced search" function because you are gonna need it with mods and help on this car.
Dave
Old Oct 15, 2008 | 06:08 PM
ferg's Avatar
thank you so much
Old Oct 15, 2008 | 11:50 PM
lopezian2004's Avatar
Master Shr3dd3r
are the reflectors in those things? take that crap out!!!
Old Oct 16, 2008 | 12:18 PM
Mazurfer's Avatar
Mine reflectors are out too! I forgot all about that, but you have to be careful and patient taking those things out!
Old Oct 16, 2008 | 04:31 PM
ferg's Avatar
i just installed the side lights and i took the reflectors out with the clear bulbs, looks good
Old Oct 16, 2008 | 04:34 PM
quazmosis's Avatar
Chode
These aren't illegal in any states are they? I've been trying to find that out. From what i gather no since everyone has them. Unless you use some other color bulb correct? But if you leave the same bulb as the car came with you should be fine correct? Even with taking out the reflectors?
Old Oct 16, 2008 | 04:42 PM
ferg's Avatar
i dont really know, i live in south florida and the cops have better things to do
Old Oct 16, 2008 | 05:04 PM
Deathcraft's Avatar
Yes, same here in Washington. Everybody has them and never heard of anybody got pulled over for having clear corners. lol
I have them and I change the bulbs every two months or something with different colors....haven't gotten pulled over for that..lol
I think cops care more about you not having front lis plate than having clear corners...atleast in WA......most cops probably think they're just OEMs
Old Oct 16, 2008 | 05:12 PM
ferg's Avatar
when i took the reflectors out and i had to think of a glue to put them back on, i used super glue, its perfect for plastic so its holding good, i hope
Old Oct 16, 2008 | 08:02 PM
nuke0907's Avatar
Never Blend In
they are illegal because they don't have amber reflectors.
Old Oct 16, 2008 | 08:06 PM
Mazurfer's Avatar
Huh? Put what back on?
Did you take them apart to get the reflector(s) out?
Everyone else was just kind reaching in there in various methods and getting them out.......without scratching of course.
Recommend you ask next time if you did take them apart.
Old Oct 16, 2008 | 08:09 PM
Mazurfer's Avatar
Correct...technically it's not the clear corners at that point, it's that the bulbs are supposed to amber. In other words, you can have amber corners with white bulbs, or clear corners with amber bulbs and you are 100% legal. Of course most of use use the clear corners and white bulbs..............so by the letter of the law in most states, that ain't legal...........oh well!
Old Oct 16, 2008 | 08:25 PM
ferg's Avatar
all i did was take off the clear from the backing, i didnt crack it or anything it was easy, and i took out the reflector of it and painted white inside, after that i found that super glue was the best to bond, it seems good and it looks perfect
Old Oct 16, 2008 | 08:26 PM
nuke0907's Avatar
Never Blend In
even if you have amber bulbs its still not legal. when your lights are off you must have an amber reflector in the front part of the side of a car.
Old Oct 16, 2008 | 08:27 PM
ferg's Avatar
i should of took pics to show you
Old Oct 16, 2008 | 08:31 PM
Mazurfer's Avatar
Ya know what.....I think you're right.........my bad.
I looked it up one time in the Florida statutes just because I was curious and I do remember something to that effect.
Old Oct 16, 2008 | 08:32 PM
Mazurfer's Avatar
Hmmmmm.....cool. Will probably be fine then.
Old Oct 16, 2008 | 08:36 PM
Master Shr3dd3r
Haha whoops! You should have definitely just gotten some needle nose pliers and wiggled the sucker out.. but I guess if your method works then who cares right?
Old Oct 16, 2008 | 08:37 PM
ferg's Avatar
well if your a good driver then cops will leave you alone, but if you drive like an ***. the cops will always remember you and know you and pull you over alot, the good news is that where i live, there kinda worried about finding gta or killings
Old Oct 16, 2008 | 08:39 PM
ferg's Avatar
ill keep you updated and see how it holds up
Crazy.8
Apr 18, 2017 03:17 PM
Solidtrance
22
Sep 4, 2015 12:47 PM
SayDfuse
Aug 3, 2015 10:41 PM
MarkX
Jul 31, 2015 07:50 AM
thewatcher101
Jul 27, 2015 09:44 PM
