New LEDs. Wow! Bright!
Old Oct 14, 2008 | 11:00 PM
Aipex8's Avatar
X e p i A
So I ended up getting two pairs of VLEDS Micro bulbs (head and fog lights) and got them installed. I'll try to get pictures this weekend, but as LEDs get brighter than HIDs, it's increasingly difficult to get pictures.
First impressions:
The light output is totally even, crisp and very bright. I was using Morimoto XB HID bulbs which are pretty high quality and the LEDs are maybe 10-20% brighter (I didn't do a ton of testing with one of each installed). The 6000K color matches my parking 194 and the V3 Tritons that I'm using for DRLs very well. My previous high end LED fog lights (SMZs - no longer sold) were 6000K, but appeared a bit whiter and closer to 5000K, so this is good news. It all looks very modern from a distance... like a Tesla or something. Love it! VLEDS also makes their H11 and H9 bulbs interchangeable, so those old SMZ are now my high beams. I'm now officially fully LED converted... like everything!
A few quick notes:
-HID to LED conversion is a bit complex and permanent. The D2S kit comes with a pass-through kit that is supposed to allow you to go through the dust cap. It unfortunately requires the driver and quite a bit of cable to remain inside the headlight housing. It won't fit. I ended up cutting large square holes in the caps so the driver could be outside the housing, then taped up the hole with 3M double sided and duct tape (been raining non-stop and no condensation inside, so I think it's good). The bulb itself is an amazing design, very easy to install and fits easily within the housing.
-The stock HID cable and socket that connects to the ballast (big metal socket and cloth sheathed cable) would require baking the headlights and taking apart to actually remove, so I was forced to cut the cable to remove the D2S socket. That makes this install permanent. I will have to buy new housings if I want to go back to HID.
-A few technical details on the HID to LED conversion: the power you are tapping into is in the wiring harness running to the headlight. Cut the sheath and find the violet/white wire on the driver side and the black/white wire on the passenger side (the ground is black on both sides). Cut the power wire (you don't want the ballast powering up any more) and connect it to the power for the LED. Tap into the ground as the same ground is used for parking, signal, high beam too, so you don't want that one cut.
-For halogen headlight people, this is a no-brainer. Maybe a bit more expensive than ebay HID kits, but it will be much easier to install, brighter, and more reliable.
-The fog light bulb install is much easier. The only issue there is that the bulb sits at a 45° angle because of how the sockets on the housing are. VLEDS recommends not having the bulb sit at 45°. They are adjustable, BUT (and this is going to be hard to explain) one of the 45° adjustment point allows you to take the collar off all together so you can't use that notch. The end result is that you can't adjust both to sit in the housings in the same position (either vertical or horizontal). You can have one vertical and one horizontal (asymmetric) or both at 45°. I chose both at 45°. I don't think it's as big of a deal with the fogs.
TL;DR: HID to LED is hard but worth it. Halogen to LED install should be easy. Fog light install is easy (bulbs sit at 45° but doesn't matter). Micro bulbs are amazing and highly recommended whether you currently have HID or halogen.
Old Oct 14, 2008 | 11:02 PM
05rex8's Avatar
sold the 8... :(
oooooo I'm gonna get me some of those
I have super white ones from v-leds too, but not nearly as bright
Old Oct 14, 2008 | 11:14 PM
nvrfalter's Avatar
tonybob failpants
pics with the HID's on? do they match the factory HID's well?
Old Oct 14, 2008 | 11:18 PM
05rex8's Avatar
sold the 8... :(
^they will not match factory hid's--factory will look yellow compared
try 6000k hids, they match pretty good
Old Oct 14, 2008 | 11:24 PM
Aipex8's Avatar
X e p i A
Yeah, I have 6000K HID bulbs, so it's a pretty close match. I'll get a few shots tomorrow at dusk. My camera sucks when it's fully dark.
Old Oct 14, 2008 | 11:32 PM
nvrfalter's Avatar
tonybob failpants
damn
Old Oct 14, 2008 | 11:41 PM
Mun1688's Avatar
Which one did u purchase cause there are a bunch of the LED site.
Can u plz post the link of each one u bought?
Old Oct 14, 2008 | 11:45 PM
tubingchamp's Avatar
What mawd bug?
Was just thinking the same... I NEED these lights! But the light codes=confusing.
Old Oct 14, 2008 | 11:56 PM
Mun1688's Avatar
lol yea
Old Oct 15, 2008 | 12:05 AM
lopezian2004's Avatar
Master Shr3dd3r
i wonder how long those fogs are gonna last...
Old Oct 15, 2008 | 12:12 AM
Mazdaspeed RX8 ver2's Avatar
got to get me a set of these, they looks awesome!!
Old Oct 15, 2008 | 12:33 AM
Decat's Avatar
Yeah those look quite a bit brighter than the LEDs I bought from AutoLumination for the fog lights.... hmmm.....
Old Oct 15, 2008 | 12:45 AM
SayNoToPistons's Avatar
Wheels, not rims!!
Night time shots?
Old Oct 15, 2008 | 12:46 AM
lilring's Avatar
Finally a MT
Yes links to each one would be nice. and how hard is it to get to the Parking lights? mine have been out since i bought the car.
Old Oct 15, 2008 | 12:47 AM
DoubleGoose's Avatar
FS Section Sniper
niiice. i have an all white light front end as well. love it.
Old Oct 15, 2008 | 01:01 AM
Aipex8's Avatar
X e p i A
Parking lights:
http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
part number: 194_4_HP_W
Corner lights:
part number: 194_4_HPF_W
Fog lights:
part number: H11_68_W
Old Oct 15, 2008 | 01:05 AM
Mun1688's Avatar
Thanks bud
Old Oct 15, 2008 | 01:08 AM
Aipex8's Avatar
X e p i A
Yeah, I'm a little worried about that also. I had a few sets of parking lights go out before I started running resistors on them. I'm not worried about the parking or corner lights at all now, the resistors really help. The fogs are unprotected though, so we'll see.
Old Oct 15, 2008 | 02:20 AM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
The fogs look great....
I'd be skeptical about how long they will last. Do they get warm at all?
Old Oct 15, 2008 | 06:39 AM
L337fpc's Avatar
ლ(ಠ益ಠლ)
holy crap! awesome lights man!!
Old Oct 15, 2008 | 08:22 AM
Ryan2008's Avatar
Registered Paratrooper
Looks good man, I'm definitely feelin them. Be sure to get some up with the HIDs on too.
Old Oct 15, 2008 | 08:44 AM
peterlemonjello's Avatar
I'd love to have the fog light led's in yellow.
Old Oct 15, 2008 | 10:26 AM
Aipex8's Avatar
X e p i A
No, they don't get warm. They don't use the same .5 watt LEDs that the 194s use (and they do get quite warm), but make up for lack of brightness with volume. The oil coolers get hot, but they don't seem to radiate much towards the foglights. I can reach my hand up there right after driving and the oil coolers are red hot but the back of the fogs are cool to the touch. I'm more worried about voltage spikes than heat.
Old Oct 15, 2008 | 10:51 AM
TeeFar's Avatar
those fogs look great... I'm gonna have to cop some. Sucks that they're so hard to install though.
Old Oct 15, 2008 | 10:57 AM
dozer's Avatar
on his 3rd rx8
really nice....
