Progress Sway Bars and Endlinks
Old Oct 9, 2008 | 06:10 PM
NoPistons4Chris's Avatar
Will the Progress sway bars work with the agency power end links?
Old Oct 9, 2008 | 07:02 PM
nuke0907's Avatar
Never Blend In
why wouldn't they? the AP and and progress sways are very comparable, almost the same price even.
Old Oct 9, 2008 | 07:30 PM
all i needed to know thanks!
Old Oct 10, 2008 | 07:35 AM
nuke0907's Avatar
Never Blend In
the front AP endlinks are adjustable so they should work perfectly. the rears though i'm not so sure about since they are not adjustable.
the sways are pretty much identical. 19mm/32mm and 3 way adjustable.
Old Oct 10, 2008 | 07:51 AM
alnielsen's Avatar
The AP endlinks are adjustable, front & rear. They are pricy though.
These are adjustable and the price is a bit better. http://www.evo-r.net/product/RX-8/LINK/index.htm
The difference between these and the AP is that with these you will have to remove one end or the endlink to adjust them. With the AP, it's not necessary to remove the endlink.
Old Oct 10, 2008 | 08:00 AM
nuke0907's Avatar
Never Blend In
you are crazy, how is a solid chunk of metal adjustable?
Old Oct 10, 2008 | 08:29 AM
Macius8's Avatar
What about the AWR endlinks? Head somewhere they are pretty good
Old Oct 10, 2008 | 10:10 PM
good stuff. tell jay swoope said hi..
Old Oct 10, 2008 | 10:29 PM
alnielsen's Avatar
You chose to show the rear. The front are adjustable. I know, I have them.
Old Oct 10, 2008 | 10:58 PM
philsbluerx8's Avatar
the reason why he pointed out the rear endlinks is because you said the AP front&rear were both adjustable.
Old Oct 11, 2008 | 12:52 AM
damn that's sweet..i like the evo-r diagram
Old Oct 11, 2008 | 12:56 AM
Spinning Sushi's Avatar
I <3 Sushi
Since the ends can rotate 360 degrees, I don't see why you can't use the AP front endlinks for the rear.
Old Oct 11, 2008 | 10:38 AM
alnielsen's Avatar
They are expensive. I may switch over to the Evo-R links. I don't like the collars that are used on the AP links. When they get loose, they no longer work right. They get sloppy. They should have used cone bushings at the heim joints. Plus in weather up here, the joints are open to the elements and corrosion.
Old Oct 11, 2008 | 06:43 PM
length,
if you are lowered.
Old Oct 12, 2008 | 04:15 PM
nuke0907's Avatar
Never Blend In
do you have pics of front and rear installed? the website only has one pic of one installed and i can't tell which one it is. plus the bottom 2 look like rod ends not endlinks, is that correct?
Old Oct 12, 2008 | 05:59 PM
Juice's Avatar
I made some poos
Here are pics of the Evo-R Endlinks:
https://www.rx8club.com/series-i-wheels-tires-brakes-suspension-55/evo-r-adjustable-endlinks-installed-143615/
Bottoms are full replacements, as well as the fronts. Fronts can adjust while on the car but the rears need to be disconnected on one end.
Old Oct 12, 2008 | 09:56 PM
juice covered it. i was under the car today. they are holding up well..
Old Oct 19, 2008 | 04:05 PM
leechieboi's Avatar
Now FI perpetual learner
i have the progress tech sways with ap front and rear links. works great
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
duworm
Oct 1, 2015 04:57 PM
Trekk
12
Sep 25, 2015 03:08 PM
Steve Dallas
Sep 19, 2015 09:39 AM
