final stage
Old Oct 8, 2008 | 08:20 AM
JGR4444's Avatar
GR
final stage
I am in the final process of putting my motor back in..
all in all it was not that hard just a few minute things and i wish i could have dropped the motor instead of picking it up out of the engine bay with the tranny on it...
but i have been searching around on here for about 2 hours trying to find a diagram of hoses and wiring... just making sure i hook everything back up right since the new motor is in and im ready to hook stuff up
any help on diagrams for wiring and hoses would be greatly appreciated
thanks!
Old Oct 8, 2008 | 10:43 AM
olddragger's Avatar
you didnt label them?
If you pulled the trans with the motor out of the top--inspect carefully the front seal in the trans--i know i know it is boted on etc--but you may want to replace that seal--its cheap and if it leaks when you reinstall then it is a lot of work to get back to it..
The harness will actually be kind of start up--kind of hard to get it messed up if you pay attention--the tricky part is getting the fuel injectors hooked up correctly on the harness. It is easy to get them mixed up.
The vacuum lines etc --too much to type! particular ? i can help. You need the manual really.
Sorry!
OD
Old Oct 9, 2008 | 08:01 AM
JGR4444's Avatar
GR
well its actually going to be longer than i thought now because the 07 wiring is not the same as the 04 so i need to change the harnesses.. and sine the new motor is already dropped in i have to do everything from a confined space which is not going to be fun.
dezau
RX-8 Racing
10
Mar 9, 2016 09:50 AM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Racingjunkie
Sep 29, 2015 05:05 PM
pjwermuth
Sep 28, 2015 11:36 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
