car running like crap
Old Oct 5, 2008 | 03:39 PM
mazdaverx7's Avatar
RX-Heaven
how many miles and have you replaced the fuel filter?
Old Oct 6, 2008 | 04:34 PM
fuel filter is build into the fuel pump, you can take it out and clean it but there is a very high chance that you might break the pump.
So just replace the pump, at ur mileage, is about time.
Plus, replace all 4 coils and plug wires if u haven't do so.
Old Oct 6, 2008 | 05:20 PM
shaunv74's Avatar
Power!!
I don't think you get misfires from a clogged cat. you typically get no top end power. Like it runs fine and dies off at 5-6K rpms.
It sounds like it could be fuel pump/filter related since your ignition is fairly new. The dealer may have suggestions on how to clean the filter without breaking the pump.
Old Oct 6, 2008 | 11:41 PM
shaunv74's Avatar
Power!!
It's easy enough to check. crawl underneath, unbolt the two spring loaded bolts, then unbolt the 3 bolts at the front of the cat and look inside. It will look melted if it's clogged.
Old Oct 7, 2008 | 09:31 AM
csl's Avatar
csl
As the MAF already cleaned, try to unplug the battery. If the next start is the same, then should be either the pump or the pulsation thing on the fuel rail. BTW, check the connectors on the fuel injectors, just for in case.
Old Oct 7, 2008 | 10:18 AM
rotary.enthusiast's Avatar
The Local Idiot
^What he said: reset the PCM's "learned behavior" and see what happens. Can't hurt.
Could also be a bad O2 sensor, bad compression, or as others have said some problem with fuel delivery (fuel pump, injector problem, etc). Being a used 04', I would get a compression test done first before spending a lot of time messing around with other stuff (assuming you didn't have one done before you bought it).
Old Oct 7, 2008 | 09:22 PM
Originally Posted by gmcmillan
alright the car is sitting at the shop. my mechanic is going to check out the fuel pressure, o2 sensors and cat.
if all is a pass for those things than it's compression test again.
i will keep you all posted
do you premix?
Old Oct 7, 2008 | 10:24 PM
mazdaverx7's Avatar
RX-Heaven
let us know what he finds. i'm thinking that that it may be fuel related.
Old Oct 7, 2008 | 11:07 PM
nope i've never premixed.
previous owner may have but i'm not sure.
fuel pump / clogged injector.. best guess..
and if the previous owner did, that would add to my comment..
Old Oct 10, 2008 | 03:04 PM
shaunv74's Avatar
Power!!
fuel system would. EG: no fuel equals no put put...
Old Oct 15, 2008 | 02:35 PM
shaunv74's Avatar
Power!!
Good that they found it. Although that shouldn't keep your engine from starting.
they can check the fuel pump first to see if it's running at all (fuse in, fuse out) and then second they can pull a fuel line and see if fuel comes out when they run the pump.
