At Only
Old Oct 4, 2008 | 09:16 AM
7MANNY7's Avatar
At Only
Hey are all you guys having the same issue with 1st gear? Its like I put the pedal to the floor and it has to get 5000 rpm before anything happens? If anyone knows how to fix it please let me know.
Old Oct 4, 2008 | 09:22 AM
greg985's Avatar
The 337
buy a domestic
Old Oct 4, 2008 | 09:29 AM
nvrfalter's Avatar
tonybob failpants
uh no dude thats the way the car is. shoulda got a mustang, brotha
Old Oct 4, 2008 | 09:44 AM
Renesis07's Avatar
Vtak just kicked in yo!!
Before I assume youre completely ignorant to the severe lack of torque:
How long have you owned the car?
Has it always been this unresponsive or did it just now start doing it?
If it just started and its ABNORMALLY unresponsive it may need new coils.
When was the last time you changed the coils, plugs, wires?
Old Oct 4, 2008 | 10:46 AM
hakuna matata!
You have an AT.. it's normal.
Old Oct 4, 2008 | 10:52 AM
chancejat's Avatar
Drive it like u stole it!
i think the op is joking.....
Old Oct 4, 2008 | 12:34 PM
NgoRX8's Avatar
hahah. joking or not, it's true.
Old Oct 4, 2008 | 12:50 PM
kvndoom's Avatar
The Slow and the Serious
What, does it not even move until you hit 5000 RPM? I'd get a doctor to check that ****. "VTEC didn't kick in, yo!"
Old Oct 4, 2008 | 01:31 PM
Drop the clutch at 5k
Get a flywheel
Old Oct 4, 2008 | 01:34 PM
NgoRX8's Avatar
he has an AT, razz.
Old Oct 4, 2008 | 02:46 PM
Renesis07's Avatar
Originally Posted by NgoRX8
he has an AT, razz.
swap that **** out yo
Old Oct 4, 2008 | 06:38 PM
04RX8man's Avatar
Rotary Powered Countryboy
this is all you need on the back of your car and it will be good to go
Old Oct 4, 2008 | 10:50 PM
7MANNY7's Avatar
I've owned the car for about a month. Love the car. The first initial response was always slow. So I'll check on the plugs and wire's and see what happens.
Old Oct 4, 2008 | 10:54 PM
7MANNY7's Avatar
I meant that it really doesn't have alot of speed on take off.(don't think I explained it correctly the first time)
Old Oct 5, 2008 | 12:26 AM
greg985's Avatar
The 337
its called 159 lb/ft
Old Oct 5, 2008 | 12:42 AM
Easy_E1's Avatar
This is normal for the NA AT. The Renesis doesn't pull power until the secondaries open at about 4250 rpm. Then it will pull a lot stronger. If you really want some low end power do some Nitrous like me. Spin the tires off the line.
Check the Dyno chart below.
Old Oct 5, 2008 | 09:41 AM
04RX8man's Avatar
^ I thought the secondaries opened at 3750rpm but maybe the AT and MT are different i guess they would b with some being a 4 port and some being 6
Old Oct 5, 2008 | 09:48 AM
greg985's Avatar
The 337
more open at around 6300 on the MT correct?
Old Oct 5, 2008 | 09:56 AM
ShellDude's Avatar
weeeeeeeeee
more == the extra 2 that the 6MT and 6AT have that the 4AT doesn't.
Old Oct 5, 2008 | 12:50 PM
7MANNY7's Avatar
Is there not another option? How about the cobb acc port? I'm trying not to go FI or nitrous.
Old Oct 5, 2008 | 01:41 PM
ShellDude's Avatar
weeeeeeeeee
The AP does help with first gear on the 4AT, most definitely. But that's not its big selling point and you'll need a tuner to work with you.
Old Oct 5, 2008 | 01:55 PM
invasion08's Avatar
higher stall speed torque converter
Old Oct 5, 2008 | 09:39 PM
kersh4w's Avatar
Hit & Run Magnet
+1
launch at 4500rpm
