Unable to start the engine
Old Oct 3, 2008 | 10:38 AM
shunt1's Avatar
This weekend, my wife was able to start my car without any problems.
Wednesday, I tried to start my car and the engine refuses to kick over.
The battery is fully charged and the car has a full tank of gas. I put tape on the belts, and they are turning when I attempt to start the engine.
I have fuel, electricity and a good starter motor. However, It still refuses to start.
Does anyone have an ideas?
Old Oct 3, 2008 | 10:49 AM
StealthTL's Avatar
Metatron
1-Do you hear the starter TRYING, or is there just a CLICK, or just nothing?
2-Turn the headlights on, and try again - do the headlights dim when you turn the key, or stay bright?
S
Old Oct 3, 2008 | 10:56 AM
shunt1's Avatar
1) The starter motor is turning the engine.
2) Headlights remain bright while trying to start the engine.
Old Oct 3, 2008 | 11:00 AM
StealthTL's Avatar
Metatron
It's flooded.
Step one - floor the gas pedal (this actually cuts off fuel flow) and crank the engine for TEN SECONDS straight. Don't lift your foot, don't stop before ten seconds. Give the starter a minute to cool off, then try to start normally, foot off the gas.
S
Old Oct 3, 2008 | 11:08 AM
shunt1's Avatar
I have already tried that. Both yesterday and this morning, so any extra fuel should have evaporated between my tests.
The engine still refuses to start.
At the moment, I am rather baffled. It is like the car's computer is refusing to allow the engine to start, but it does not tell me why.
Old Oct 3, 2008 | 11:29 AM
ndhoffma's Avatar
Keep trying... maybe even crank it for 20-30 seconds. I had a similar issue with my car once, and I just had to keep trying for a while, playing with foot on and off the gas and it eventually started.
Old Oct 3, 2008 | 11:33 AM
chancejat's Avatar
Drive it like u stole it!
flooooooded.....push start it and pop the clutch....do it like 3-4 times and itll start....
Old Oct 3, 2008 | 11:44 AM
shunt1's Avatar
It 'almost' started, but at least I got some kick out of the engine this time.
Will try it again, once the battery is recharged.
Old Oct 3, 2008 | 12:03 PM
ndhoffma's Avatar
Yeah, when I ended up getting mine to start, I talked to the dealer... they pretty much said I could have it towed in, but they would do the same routine there anyway
Old Oct 3, 2008 | 12:12 PM
shunt1's Avatar
I live 150 miles away from the closest Mazda dealer, so I am rather stuck.
With help from you and other members of the RX8club, my car will soon run again.
At least the engine is kicking...
Old Oct 3, 2008 | 12:19 PM
StealthTL's Avatar
Metatron
Yes, a fresh battery and a shot of 'starting fluid' ether is what I used on my RX-3, in the day......
S
Old Oct 3, 2008 | 01:15 PM
shunt1's Avatar
Following the advise given to me on this thread, I finally got my engine started.
For the next 10 minutes, very dense blue smoke was being emitted from the tail pipes and it was rather scary to watch.
However, at the moment, my car is running in idle.
Thanks for you help!
Old Oct 3, 2008 | 09:51 PM
Old Rotor's Avatar
Do you know how you FLOODED it so you wont do it again?
Old Oct 4, 2008 | 01:29 AM
daisuke's Avatar
rotorized!!!
you should replace your spark plugs at this point, they will have gotten pretty fouled up from all that
Audio Concepts ATL
Sep 26, 2021 01:59 PM
vapor2
Nov 3, 2020 03:38 PM
Rx808BI
Aug 9, 2015 10:06 AM
dbarber
Jul 25, 2015 01:34 PM
