Blown Rear Diff??
Old Sep 24, 2008 | 07:49 AM
Greenblurr93's Avatar
Sotally Tober
Blown Rear Diff??
I think i may have blown the rear diff out of my car... brought it to mazda the dealer agreed it was bad and called Mazda to get it covered under warrenty. A Rep from MNO came out and said the rear end wasnt blown, it just needed a fluid change... so i took these pics and vid while changing the fluid... tell me this rear diff isnt blown... (YOU NEED SOUND!)
http://www.altspace.com/rx8/james/bolt2.jpg
http://www.altspace.com/rx8/james/bolt1.jpg
http://www.altspace.com/rx8/james/blown_diff.html
Old Sep 24, 2008 | 12:23 PM
wats that crack crack crack crack sound ?
and the pic of your drain plug is pretty normal. the magnet is there for that reason.
Old Sep 24, 2008 | 12:27 PM
Sotally Tober
that sounds is coming from the diff.... also note that when you spin the driverside wheel both spin... when you spin the pass wheel, it makes that sound and the other side doesnt spin
Old Sep 24, 2008 | 12:29 PM
rear diff should NOT make any sound, at least not like that.
so yes, you have a problem in there. it still works now, but Its probably on its last leg.
Old Sep 24, 2008 | 12:35 PM
Sotally Tober
i know it wont last much longer at all... and the tech AND service manager at the dealership agree... however the rep from Mazda insisted that its fine and just needs a flush..
Old Sep 24, 2008 | 02:13 PM
Juice's Avatar
I made some poos
I woud have them flush it. If it is still bad, then tell them to fix it and give you a reimbursement for the fluid change since they recommended it and it didn't do squat.
Old Sep 24, 2008 | 02:16 PM
Sotally Tober
i asked that, and if they did it, and it was still bad... i wouldnt get reimbursed because it was 'maintenance' and i didnt wanna spend the $200 to have them do it... so a wendy's meal and a trip to Cape Cod later, the diff is flushed and has Royal Purple 75w-90 in it... ill wait a week and bring it back and hopefully get a new diff installed since mazda should be happy...
Old Sep 24, 2008 | 03:45 PM
how many miles u have on your car?
cuz if I remember correctly the maintenance calls for 60K miles (for Rear diff)
You should've just do it yourself, or buy the fluid and have some local garage to do it for you, its mad easy, probably cost less than 50 bux. then they would not have any more excuse to deny anything.
Old Sep 24, 2008 | 05:32 PM
Sotally Tober
they said the manual calls for 30k... i have 39k... and i did my own flush with generic diff fluid, there is now royal purple in it.. i did it my self in my friends garage..
Old Sep 24, 2008 | 05:44 PM
Easy_E1's Avatar
I'm sorry but how stupid is that Mazda Rep? As far as the drain plug that's not a whole lot of metal. I would just rev it up to 9000 and drop the clutch. That should finalize the deal.
I blew mine at 3000 miles and it was so full of metal it was glopping out when they drained it. I had a pile of metal about the size of an egg. And it was just shuttering going around corners.
Old Sep 24, 2008 | 06:00 PM
Sotally Tober
He didnt seem all there.... yeah going around corners with any decent speed all you hear is the spider gears grinding on eachother...
Old Sep 24, 2008 | 06:03 PM
altspace's Avatar
Eccentric Shafting
It's ok, you can admit it was me. You forgot to mention how much metalic particles we found after the first drain. Never seen that much under normal conditions. Hearing the sound in person put shivers in my spine.
Old Sep 24, 2008 | 08:02 PM
Guy Hollywood's Avatar
Sounds friggin terrible dude. Rear diff flush my ***...What a moron
Old Sep 25, 2008 | 09:50 PM
musclecarconvrt's Avatar
You need a new rear diff. The rep that said it just needed a flush is either a complete idiot or is a dishonest piece of crap. Your rear diff should never make a sound when gently spun by hand and it should never ever knock. If it still moves the car at all, it won't last very long.
Old Sep 26, 2008 | 10:10 PM
Clavius's Avatar
Its all about Style...
This is probably the same Mazda guy who said to charge me for a decarb even it my motor fails. Something is up and I hope your not driving down the highway in the left lane when everything explodes.
Old Sep 26, 2008 | 10:29 PM
fahrfegneugen's Avatar
That would suck if that thing seized up while you driving it. How does it sound when you drive it? like loud tires?
I just changed my diff. fluid and there was not nearly that much metal on my drain plug.
Old Sep 26, 2008 | 11:02 PM
Sotally Tober
yes.. and yes... ?
Old Sep 26, 2008 | 11:11 PM
^haha
I am really sorry to hear that though
Old Sep 26, 2008 | 11:34 PM
they cannot suggest you to do any of the things other than the one listed in the service manual.
since when is there a line that saids "Flush the rear diff" in the manual? at least not in mine. All it saids is drain and refill.
So that Mazda rep is just full of bull, as long as you have the receipts of the fluid that you bought with the right spec. Tell them to fix the rear diff or u'll bring this to the court.
Old Sep 26, 2008 | 11:47 PM
tunerwannab's Avatar
That sucks! Hop mazda steps up with no more hassle.
GL
WranglerFan
May 31, 2022 07:51 AM
RXFEVER
Aug 29, 2018 10:14 AM
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
nowakm99
Oct 9, 2015 07:10 AM
Paul_Y
Sep 21, 2015 02:23 PM
