Tokico Dspec
Old Sep 23, 2008 | 09:59 AM
enthegen's Avatar
wfc#046
Tokico Dspec
So I recently purchased tein s.tech lower springs and I was going to also purchase shocks before I put the springs so I can just do it all at once. I was looking at the TOKICO DSPEC ADJ. SHOCKS.. Has anyone used these? Or does anyone have some other shock absorbers that they recommend?
Old Sep 23, 2008 | 10:19 AM
benh's Avatar
enthegen,
Do a search, there are lots of info on shocks here.
Old Sep 23, 2008 | 10:37 AM
enthegen's Avatar
wfc#046
I had tried the search before I posted but for some reason the search was not working for me.. everytime I used it, it gave me page cannot be displayed.
Old Sep 23, 2008 | 10:53 AM
DarkBrew's Avatar
Extraordinary Engineering
I have the D-Specs and would recommend them.
Old Sep 23, 2008 | 11:24 AM
RedefineRX8's Avatar
Super-impreza!
I have that exact set up. S-techs with the Tokicos. To be honest, for a daily driven car it's perfect, easy adjustability and a good investment. It's just not stiff enough for me
Old Sep 23, 2008 | 12:27 PM
imput1234's Avatar
I ♥ Drifting!!!
Auto RnD has a group buy on these right now
Old Sep 23, 2008 | 01:12 PM
Optical TDI's Avatar
I love them. HPDE days just turn then to a stiffer setting, plus you can play with the difference between front and rear to get the oversteer or understeer if you prefer.
For the street the full still setting is WAY too harsh in my opinion. I use Racing Beat springs and Hotchkis bars front and rear. It's the best deal out there for not going to a fully adjustable coilover system.
Old Sep 23, 2008 | 02:00 PM
Ever Hernandez's Avatar
Rx8_4eVeR
^+1 I also had the same set up before getting coilovers. Don't forget the cables for the rear shocks.
Old Sep 23, 2008 | 11:53 PM
gundarx's Avatar
Hummmmm...
I have the same suspension set-up as you! Just installed this weekend. How many turns do you use on all corners for daily driving? I tried 7 turns from full firm and I didn't like it at all Now on 5.5 turns from firm.. will play around some more!
Old Sep 24, 2008 | 03:53 AM
DarkBrew's Avatar
I'm using three turns from full stiff which is a bit firmer than stock and perfect with the springs and sways for street use.
Old Sep 24, 2008 | 08:49 PM
gundarx's Avatar
Hummmmm...
Thanks. I wish North Jersey roads were better so I wouldn't mind the higher damping rates. I'll try that setting soon though
Old Sep 24, 2008 | 10:40 PM
tunerwannab's Avatar
I was just going to start a thread to ask about this. I also have the s techs and was wondering what would be the BEST shocks to pare them with. My car is a dailey driver and I plan to track it next spring. Aslo what sways would you guys reccomend?
Sorry for the ramble/threadjack
Old Oct 4, 2008 | 09:45 PM
aliveoutofhabit's Avatar
HAIGUYZ!
We don't has teh shocks.
...they're called struts
Old Oct 5, 2008 | 12:30 AM
djcharlee's Avatar
^^LOL
For sure.. BTW I have this set up in the front. Waiting for a replacement rear to fininsh my install. The dumb *** installer broke one of my rear struts.
I like the front though..
Old Apr 16, 2009 | 01:28 PM
ferg's Avatar
quick question the d-specs, when you turn the settings, it gets lower? and softer the car get higher?
Old Apr 16, 2009 | 01:46 PM
Easy_E1's Avatar
The ride height is mandated by the spring you use. Adjusting the shock dampening will not effect ride height.
Old Apr 16, 2009 | 08:43 PM
the only thing the struts do is allow you to control the dampening. If you're on the track you can adjust them to be super stiff and for DD they can be soft.
Only with coilovers can your raise/lower your car at will
Old Apr 16, 2009 | 09:54 PM
G-ReX's Avatar
A Torque-Free Zone
I love the D-Specs. I also use 3 turns off full for the street. 4-5 turns is probably closer to stock. I've found 1.5 turns on the front and 1 on the rear keeps the car neutral on the track, but I have stock sways and springs.
enricofl
Feb 12, 2007 12:14 PM
iammemares
Good Guy/Bad Guy
Jan 10, 2007 12:48 PM
iammemares
Dec 27, 2006 11:42 PM
gh0st
Sep 14, 2005 02:01 PM
