Shaking at 1700 RPMs
Old Sep 22, 2008 | 11:44 AM
StockEG6's Avatar
I'm having an issue with my RX8. When driving for the first few minutes after warming the engine, I get alot of shaking at 1700 RPMs. If I bring the revs up past that, the car drives fine. This is VERY annoying when you change gears and the RPM drops to 1700 because the car shakes alot. You guys may be thinking that it's because I'm shifting too early but the car is an auto (I know...) and does the gear changes itself.
Old Sep 22, 2008 | 11:55 AM
cjkim's Avatar
^noob
engine mount
Old Sep 22, 2008 | 12:02 PM
StockEG6's Avatar
I don't think that it's the engine mount. It doesn't stop shaking until you give it more gas and get past 1700 RPMs. An engine mount causes vibrations throughout the power band, especially on hard shifts.
I'm thinking that it's misfiring but I just want to make sure. I know that it's not detonating because I don't get a CEL. Btw, how often are you supposed to change the spark plugs on this car? I think that there is 36K miles on it (bought it used) and the spark plugs have never (to my knowledge) been replaced.
Old Sep 22, 2008 | 12:56 PM
cjkim's Avatar
^noob
start with mounts.
then plugs, coils, wires
i still say mounts though
Old Sep 22, 2008 | 01:04 PM
StockEG6's Avatar
What would cause a mount to let the engine shake at ONLY 1700 RPMs? If you accelerate and get to 1700, it shakes. If you decelerate to 1700, it shakes.
Old Sep 22, 2008 | 01:14 PM
cjkim's Avatar
^noob
check neutral
Old Sep 22, 2008 | 02:54 PM
kersh4w's Avatar
Hit & Run Magnet
the mounts could be damaged in a way that the engine mounts and engine @ 1700 vibrate on a sympathetic frequency causing a lot of vibration at only that specific rpm.
Old Sep 22, 2008 | 03:50 PM
costello's Avatar
^^ Very true. I had torn engine mounts on my 99 Miata and it vibrated a lot at idle. Anything above idle and it felt normal.
Old Sep 23, 2008 | 08:51 PM
04RX8man's Avatar
Rotary Powered Countryboy
motor mounts/ maybe coils and plugs but i would not think so i would check engine mounts
Old Sep 23, 2008 | 08:59 PM
Easy_E1's Avatar
Try sitting at a stop in first gear in manual mode. Then shift it to second gear, still at a stop. Do you hear or feel a difference in the engine. I had a bad mount and if you had a wall next to you you could hear a difference in the sound of the engine.
I have an AT also. Been through three sets of engine mounts in 60,000 miles.
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
D13
Oct 1, 2015 07:55 AM
tommy26Germany
Sep 29, 2015 10:33 AM
