someone turn my 1/8 into 1/4 time
Old Sep 13, 2008 | 07:36 AM
Mr.&Mrs.Magic's Avatar
went to the drag strip last night and I need some to give me an estimate for what my 1/4 mile time would be.
reaction: .536
60ft: 2.416
330ft: 6.497
594ft: 9.230
1/8ET: 9.847
1/8MPH: 72.83
Attached Thumbnails someone turn my 1/8 into 1/4 time-d-001.jpg
Old Sep 13, 2008 | 09:11 AM
SouthFL's Avatar
http://www.fl-thirdgen.org/quartermileconversion.html
^ estimates are pretty close.
Work on getting that 60' down. 2.4 sec. leaves room for much, much improvement. Figure for every tenth taken off your 60', about a tenth and a half is taken off your ET.
Old Sep 13, 2008 | 09:13 AM
chancejat's Avatar
Drive it like u stole it!
i hear if you multiply your 1/8mile time by 1.56 it gives a pretty good 1/4 time est.
so ....its about a 15.3......i see your 60t is a 2.4 you need to work on your launch and try to get a 2.0-2.1 and you will run lower 9's in the 1/8 and mid 14's in the 1/4....launching is pretty difficult in the 8 you need just enough wheel spin to stay in the power band or youll bog down......ive ran 9.8 in the 1/8 with traction on.....
Old Sep 13, 2008 | 09:28 AM
SouthFL's Avatar
Why launch with TCS on? You will never cut a good time that way. Or was that your point?
Old Sep 13, 2008 | 09:32 AM
chancejat's Avatar
thats my point....ive also run a 9.1 with dsc off...which would equal a 14.2...
Old Sep 13, 2008 | 12:59 PM
that actually was one of my worst 60ft. I had a 2.239, 2.257, 2.336 all with slower ET's. When I ran the 9.847 I was spinning like a champ all the way through first and a lot in second(first time that has ever happened in this car) so I figured my ET was going to be pretty slow but it turned out to be the best . I figure with a good set of sticky 245's I could launch better/harder. Currently i'm running 225 federal tires which I believe are perfectly built for crap.
Old Sep 13, 2008 | 06:26 PM
SouthFL's Avatar
Bogging?
Old Sep 13, 2008 | 06:28 PM
Bogging?
I'm pretty sure no??
Old Sep 13, 2008 | 06:31 PM
SouthFL's Avatar
I would guess so also. Bog would take you out of the powerband and lose momentum- offsetting the benefit of the better 60' time.
Old Sep 13, 2008 | 06:41 PM
kersh4w's Avatar
Hit & Run Magnet
try to start moving in 6th gear. thats called bogging the engine down.
Old Sep 13, 2008 | 07:09 PM
you ran a 1/8 mile time
anything else is a guess ....
Old Sep 14, 2008 | 09:45 AM
SouthFL's Avatar
Yeah, but the extrapolation process is rather accurate.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
F51
Aug 2, 2021 04:07 AM
Nisaja
Aug 6, 2015 01:27 AM
SIllver
Aug 1, 2015 07:34 PM
digitalmonkey79
Jul 29, 2015 12:09 AM
