I have a few Trouble Codes, anyone know how to fix them?
Old Sep 6, 2008 | 05:07 PM
simplyphp's Avatar
Other than the Cobb AccessPort from MM, I haven't done any true mods to my car yet, just a body kit & aesthetics that wouldn't do anything to how the car actually works. I have the default v1.0 flash and my STFT is at 0/1 so that's fine. Problem is, my TPMS monitoring light has been flashing for about a year and a half now, so I plugged in the AccessPort today and lo & behold there were these errors (all information is from a DTC manual, Mazda may deviate some from these values but their raw entry is also correlated in case its of use to anyone):
CAN Bus faults:
IC U1900, RAW: D900, Meaning: CAN Communication Bus Fault - Receive Error
EPS U1900, RAW: D900, Meaning: CAN Communication Bus Fault - Receive Error
RKE U1900, RAW: D900, Meaning: CAN Communication Bus Fault - Receive Error
TPMS Errors:
TPMS U2616, RAW: E616, Meaning: Left front tire pressure sensor is Not Responding
TPMS U2617, RAW: E617, Meaning: Right front tire pressure sensor is Not Responding
TPMS U2618, RAW: E618, Meaning: Left rear tire pressure sensor is Not Responding
TCM Error:
TCM U0100, RAW: C100, Meaning: Lost Communication With ECM / PCM A
So I cleared the errors, waited, restarted car, drove around some, checked for errors, and lo & behold:
RKE P0039, RAW: 0039, Meaning: Turbo/Super Charger Bypass Valve Control Circuit Range/Performance
So I know that my TPMS sensors, likely in all 4 wheels not just 3, are either broken or were taken out or something... I'm not 100% certain. Discount Tire Co told me to take it to Mazda as they didn't have anything to check it with, but of course I prefer to check on the forums first before giving the stealership my car.
My main concern are the IC/EPS/RKE/TCM errors because I don't know what those pertain to. My initial thought was the U1900 error was in some way associated or caused by the U261x errors, i.e. the tire pressure monitoring system was not communicating with the CAN Communication Bus because they senors are either broke or non-existent (removed by prior owner or an idiot changing the tires out).
The other possibility is that the CAN Comm. bus errors were caused by me swapping out my tail brake lights & turn signals with LED lights, and of course inserting them backwards both times, so maybe the computer registered an error with the electrical bus, I know that my wife's old 97 Camry had a light come on when her back left brake light went out, so maybe my RX-8 registered some sort of problem as well, I am not certain.
The lost communication with ECM/PCM error, TCM U0100, I don't really have a good clue.
And, for the RKE P0039, it supposedly has to do with "Turbo/Super Charger Bypass Valve Control Circuit Range/Performance", but I do not have a turbo (yet) nor any bypass valve.. so, taking the next few words and making a meaning of them: "circuit range/performance", I might be able to explain that one as well but again am not sure. Since I replaced the back turn lights with LEDs, my lights all blink faster. I mean, when I go to signal left or right, my turn arrows on my dash go 90 to nothing and my front lights do the same, and my back LEDs look normal. My guess here is that the bus which carries the electrical signal hits the LEDs and it registers that it hit, hit hit hit hit, but the front ones are like, hit... pause.. hit... pause.. hit, so maybe it's the systems way of adjusting itself, sending the signal faster to the front lights & the cluster panel, but it also stores an error message that the performance is different - although honestly I feel that may be stretching it because it doesn't have **** to do with a turbo/super charger bypass valve so I'm just looking for a reason anywhere I can.
Any help?
Old Sep 6, 2008 | 05:43 PM
simplyphp's Avatar
It's an 04 Automatic, I'll probably just be taking it to the stealership so they can *** rape me.
Old Dec 1, 2008 | 09:56 AM
AlTitaniumCar's Avatar
Did the dealership ever tell you what they did to resolve the P0039 code? I just had this one rear its ugly head on me...
Old Apr 15, 2009 | 02:43 PM
dandan's Avatar
I also have this RKE P0039 code show up on my Cobb AP.
Anyone have any idea what it means?
The car is an 05 auto, N/A.
Old Apr 15, 2009 | 02:51 PM
MM said that code means nothing.
We have yet to find out what it means.
WranglerFan
Aug 21, 2022 01:29 PM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
Forevermore
Sep 20, 2015 01:04 PM
Vedivan1
Sep 18, 2015 12:39 PM
Irvinb16
Sep 11, 2015 10:27 PM
