HELP ME!!Rattling noise in exuast somewhere!
Old Sep 4, 2008 | 11:36 PM
Jon316G's Avatar
Grasshopper
Wow... I would suspect multiple issues here.
1) The rattling could be a heat shield.
Just this past weekend I found that the shield on my exhaust manifold was split and rattling against a transmission's bracket to the frame. Best thing to do is get under the car with someone revving it and feel around (with gloves on).
2) CEL for small fuel emissions leak is usually the gas cap.
3) Severe lack of power is usually time for new plugs/wires/coils and with you being at 64K miles, its very likely.
Now... its possible that ALL of these are related to a bad cat, but you would usually have a CEL code for the rear O2 sensor.
Old Sep 4, 2008 | 11:48 PM
Jon316G's Avatar
Grasshopper
Once you tighten the gas cap, it'll take a few drive cycles to clear the code.
I just had to replace the gas cap on my '04.
Everything looked fine and I too cleaned it, but it went away after the new gas cap.
Never heard of a hole in the exhaust causing an emission leak.
Old Sep 5, 2008 | 12:00 AM
Jon316G's Avatar
Grasshopper
Easy to change out!
Here are a couple links from the DIY section that explains how to change out the plugs:
https://www.rx8club.com/showthread.p...ighlight=plugs
Get the NGK plugs from Sparkplugs.com:
http://sparkplugs.com/results_app.as...1&AAIA=1416844
Old Sep 5, 2008 | 12:24 AM
Easy_E1's Avatar
Check the CAT.
Old Sep 5, 2008 | 12:42 AM
Jon316G's Avatar
Grasshopper
Here is a link for the coils:
https://www.rx8club.com/showthread.p...ighlight=coils
Here is a link for the wires:
Far as the heat shield, I was too lazy to remove it to have it welded.
I just wrapped a piece of stainless steel wire around it.
And like Easy_E1 mentioned... check your cat too.
Now, all these links were found using the search function at the top.
This site has a wealth of information on this car, so utilize it.
Old Sep 5, 2008 | 04:08 AM
wow,
and motor mounts where a huge issue on the 04 at.
Old Sep 5, 2008 | 08:28 AM
greg985's Avatar
The 337
could have a cloged Cat, had that on my last car with similar simptoms (sp?)
Old Sep 5, 2008 | 11:36 AM
RK's Avatar
RK
It's Not Easy Being Green
+1 on the cat. When that goes pieces of it can end up in the exhaust and rattle around in there. I'd put my money on that.
Old Sep 5, 2008 | 11:46 AM
rattle + loss of power at high rpms sounds like a cat issue.
RevMeHarder
Jun 1, 2026 02:30 PM
Mane
Nov 20, 2015 12:16 PM
nowakm99
Oct 9, 2015 07:10 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
