sway bar or strut bar??
Old Sep 2, 2008 | 07:29 PM
dschreiner's Avatar
just a dumb question i looked online to find the difference between a sway or strut bar. now i cant really find a clear answer....are they the same thing except a sway bar is adjustable? i just need some clarification thanks
Old Sep 2, 2008 | 07:37 PM
05rex8's Avatar
sold the 8... :(
strut bars fit over the struts....like the stock one your car came with in your engine bay....sways are part of the suspension underneath the car.......I can't believe you didn't find a clear answer searching around this forum.....try harder
Old Sep 2, 2008 | 07:49 PM
invasion08's Avatar
A strut bar is designed to reduce this strut tower flex by tying two parallel strut towers together. This transmits the load of each strut tower during cornering via tension and compression of the strut bar which shares the load between both towers and reduces chassis flex.
Anti-roll bars provide two main functions:
The first function is the reduction of body lean. The reduction of body lean is dependent on the total roll stiffness of the vehicle. Increasing the total roll stiffness of a vehicle does not change the steady state total load (weight) transfer from the inside wheels to the outside wheels, it only reduces body lean. The total lateral load transfer is determined by the CG height and track width.
The other function of anti roll bars is to tune the high g-force / limit understeer behavior of the vehicle. The limit understeer behavior is tuned by changing the proportion of the total roll stiffness that comes from the front and rear axles. Increasing the proportion of roll stiffness at the front will increase the proportion of the total weight transfer that the front axle reacts and decrease the proportion that the rear axle reacts. This will cause the outer front wheel to run at a higher slip angle, and the outer rear wheel to run at a lower slip angle, which is an understeer effect. Increasing the proportion of roll stiffness at the rear axle will have the opposite effect and decrease understeer.
Old Sep 3, 2008 | 12:37 AM
damn, these guys got the answer pretty well covered.
What are you looking to do to your car? want less body roll? bling?
Old Sep 3, 2008 | 12:58 AM
NgoRX8's Avatar
in easy form:
strut helps the structure
anti-sway helps it not sway
haha, ok there's a lil more to it than that, but you can see there different right there.
200.mph
Dec 10, 2018 03:49 PM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
zoom44
General Automotive
Nov 16, 2015 11:38 PM
duworm
Oct 1, 2015 04:57 PM
