Odd sound when hitting 8k-9k RPMs
Old Aug 31, 2008 | 12:57 PM
kjullion's Avatar
Hi,
I have an '06 Shinka, and from the day I bought it I have observed this odd noise when hitting the upper end of the RPM range. I think that the noise is originating --generally-- near the back of the glove box. The sound can best be described as heavy wind passing over a leaf or two, it's a loud fluttering noise. It's loud enough that I can hear it over the din of my radio which I typically set to around the #12 volume level.
Can anyone suggest if this is normal behavior or if the might have an idea what might be the cause of it if it's not normal behavior? I think the cabin air filter is located behind the glove box, so maybe a leave or other debris has gotten in there and is only audible at high speeds...?
Thanks in advance.
Old Aug 31, 2008 | 01:00 PM
laythor's Avatar
I zoom therefore I am.
check the filter behind the glove box
chancejat's Avatar
Drive it like u stole it!
its the "sand in a blender sound".......alot of people get it.....my car does it from 3-4k...theory is its cavitation in the water pump...but im not sure.....
To be named later's Avatar
Now with 25% more fluff..
One can hit 8K-9K RPM's at a variety of different speeds......so does it do this at a particular speed only?
Old Aug 31, 2008 | 01:29 PM
kjullion's Avatar
40-50mph range
If I were to guess I would say in the 40-50mph range. I haven't really made detailed observations, but will try to do that and report back.
Yes, it's a lot like "sand in the blender" type sound...
It's time to replace my cabin air filter so I'm hoping once I do it, all will be revealed.
Old Sep 3, 2008 | 08:24 PM
MikeBusch2's Avatar
I've noticed the same sound, but in my opinion, it sounds more like gurgling water. 8K+ RPM in any gear.
Old Sep 21, 2008 | 01:43 PM
wb rx-8's Avatar
HKS Posterboy
[QUOTE=MikeBusch2;2625078]I've noticed the same sound, but in my opinion, it sounds more like gurgling water. 8K+ RPM in any gear.[/QUOTE
so have i. i have an auto. what could it be?
Old Nov 16, 2008 | 08:33 PM
Chakara's Avatar
I've had my 06 since new. It has always had a sound similar to what you described. The dealer initially said it was a known issue - related to flow through the heater core. They also said it was a known issue with no resolution.
Last trip to the dealer I asked about it again - he looked and Mazda has a fix for it now - something do with the piping for the heater core. Anyway, they did the fix under warranty and it solved the noise problem.....
-Chak
PS: Good description of the sound...the leaves in wind thing.
Old Nov 16, 2008 | 08:51 PM
Triperformance's Avatar
In other words another TSB that should be announced?
Old Nov 16, 2008 | 08:55 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
It's a well known issue for some. If you do a search all kinds of stuff will come up.
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
05rx8mazda
Nov 28, 2015 09:42 AM
Tsurugi
Sep 7, 2015 08:27 PM
mattymack
Sep 6, 2015 10:33 PM
