Coolant Temperature Sensor (CTS)
Old Aug 31, 2008 | 12:55 PM
boo's Avatar
boo
Question Coolant Temperature Sensor (CTS)
Does any one have a diagram that points out the location of the CTS sensor?
Old Aug 31, 2008 | 08:39 PM
Thermostat housing below the alternator area
Old Sep 1, 2008 | 12:27 AM
csl's Avatar
csl
The reed switch will rarely give problem. Check the magnetic float then see where is the water goes at constant high rpm. I put 2 cm above the max water level and so far don't see any light coming up yet.
Old Sep 1, 2008 | 01:56 AM
MazdaManiac's Avatar
He didn't ask about the level sensor. He wants to know where the temp sensor is, which was answered correctly.
That said, the level sensor in the bottle has a fairly high failure rate. Just search around here.
Old Sep 1, 2008 | 03:22 AM
boo's Avatar
boo
thanks guys....I bought a GT tuner which usually clips in the air intake sensor, since the 8 has 5 wires the instructions reccomend to clip it to the CTS sensor. I am sure its not gonna make much of a difference in performance or fuel efficiency as the product brags but thought of giving it a try.
Old Sep 1, 2008 | 03:26 AM
Its just gonna make the car overheat.
Old Sep 1, 2008 | 01:09 PM
boo's Avatar
boo
Did you already try it? Why do u say so?
Old Sep 1, 2008 | 01:21 PM
Because I know how the PCM works intimately and I know what the CTS does.
Old Sep 1, 2008 | 01:22 PM
Don''t mess with the CTS wiring...it will cause you tons of grief. It's one of the sensors that will throw the car into limp mode if the ECU doesn't like the readings it is giving.
You can't use cheap sensor mods to do ANYTHING on this car....
Old Sep 1, 2008 | 01:37 PM
MM knows a thing or two about our PCM. I'd listen to him.
Old Sep 1, 2008 | 01:42 PM
Nice try boo. I see you only have 5 posts. Have you tried reading the stickies in the tech section yet?
There's lots of good info in the tech section.
Old Sep 1, 2008 | 03:16 PM
this thread has failed.
Old Sep 1, 2008 | 10:03 PM
boo's Avatar
boo
I guess I'll listen to the gurus' then
Old Sep 2, 2008 | 09:54 AM
csl's Avatar
csl
Thanks MM for the correction
Here is the coolant temperature sensor location -
Old Sep 2, 2008 | 10:46 AM
hakuna matata!
So basically this thread should be renamed "Where is my CTS? My performance chip needs it to tap..!!11"..
Old Sep 3, 2008 | 09:28 AM
boo's Avatar
boo
Thnx CSL that's exactly what I was looking for....but I think I'm gonna listen to MM and not tap it....
Old Mar 17, 2009 | 10:11 AM
Durwood's Avatar
CTS and Squirls
Saturday my 8 started and died. I'm like great, its flooded now. Finally got it started and noticed my check engine light was on, the stability control dash light was on, and my engine temperature wouldn't budge. OBD said CTS failure. Bought one after finding the location on this thread so I could replace it. Looked for the CTS sensor and found a bunch of acorns beneath it and a chewed green wire on the connector. Took nearly two hours trying to splice that sucker as its a very tight fit. Found a bunch of acorns under the airbox also. Squirls and chipmonks love RX-8s too. I'm buying a BB gun.
Thanks for the schematic.
Old Dec 29, 2015 | 10:57 AM
Austin_lemke23's Avatar
Issues upon replacing sensor
So I took on the project of replacing my engine coolant temperature, didn't drain the coolant and did spill some on the engine block where the fuel injector is. Cleaned up a little. Now the car stated just fine before replacing but I CEL for this sensor and my traction control light also comes on when the sensor glitches. However after replacing I can not get my rx8 to ignite the starting system sounds healthy. It almost seems there is no spark. I did purchase the part off of eBay for cheap thinking this was a universal part. Anyone have any suggestion on what could be the cause for my car not firing?
Old Dec 29, 2015 | 11:43 AM
Well it could be the wrong sensor, or a bad sensor, and it is a very important sensor. Did you disconnect the battery before installing it?
Old Jan 2, 2016 | 09:42 PM
Yes I did disconnect the battery and I tried resetting my ECU before trying to start up. Feel like my only option now is to buy a new sensor and hope it is a faulty part I got.
92trbolzr
May 18, 2025 09:04 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
tjohnmeyer
Sep 28, 2017 05:03 PM
tommy26Germany
Sep 29, 2015 10:33 AM
drlubell
Sep 26, 2015 11:58 PM
