goal--under 3K lbs on the track
Old Aug 30, 2008 | 11:54 AM
olddragger's Avatar
current wgt 3150 with 1/2 tank(roadracing no autocross) --i have the damn sunroof, but cloth interior. 6 speed blah bah blah, battery thing i am aware of and a 680 odessy is on standby for track events. wgt was with oem battery.
how can i get to my goal and still have a comfortable daily driver--can it be done?
i also sure like the undertrays on the 2009!
olddragger
Old Aug 30, 2008 | 12:14 PM
racewithroar's Avatar
150 lbs and still have a comfortable daily driver? That's a tough one. Not sure it's possible.
But here is where I would start:
Lighter wheels and brake rotors.
Lighter seats with lighter mounting brackets. Think about removing the rear seats.
Take all the liners and everything out of the trunk, engine bay, etc.
That's probably all that you'll be able to do without if you still want comfort. If you want to do a little more think about removing the heater core and a/c unit, and everything that goes with them.
That's what I can think of off the top of my head.
--Adam
Old Aug 30, 2008 | 03:20 PM
imput1234's Avatar
I ♥ Drifting!!!
gutting the trunk + lightening the entire exhaust system (single) + battery + wheels might be a 100lb reduction
you can also get FIA approved racing seats that are light.
Old Aug 30, 2008 | 04:00 PM
tunerwannab's Avatar
Wheels, If you could run a single exhaust with no cat that would probably help a lot. I dont know how often you track but maby take out the rear seats when you do? only a couple pounds but empty your washer fluid when you track. every little bit helps.
Old Aug 30, 2008 | 05:11 PM
Spin9k's Avatar
Momentum Keeps Me Going
I was 3147lbs when cornerweighted with Enkei 275/35/18 RT-615s. 1/2 tank and my weight in the drivers seat (150). For track -24lbs for 17" Enkeis with 255 Nitto NT01s, -24lbs remove rear seats, remove jack et al ~15lbs = 3084lbs
other weight mods minus:
Odessy 680
RB 2p frnt rotors
Corksport CATback
other weight mods plus:
Autoexe strut braces
Trunk dynomated
Fire extinquisher
For a GT, there not much else to go if you want the everyday conveniences.
Old Aug 30, 2008 | 05:29 PM
Brettus's Avatar
Boosted Kiwi
Ti exhaust cuts a lot of weight - mine weighs about 13 lbs
Old Aug 30, 2008 | 05:41 PM
MazdaManiac's Avatar
How come you guys are so heavy?
My car - with me in it and about 1/2 tank of gas is 3200.
I have full leather, a subwoofer, sunroof, car computer and a turbo system with a vertical door conversion and I'm lugging around a water meth system and a full MS kit and 19" blingy rims.
Of course, I only weigh 155, but still...
Old Aug 30, 2008 | 06:41 PM
olddragger's Avatar
gravity is stronger in Ga
Good idea on the exhaust i had not thought of that part.
maybe the driver can lose 10lbs or so too.
Thanks Roar--i am trying to get lean for when we meet in TT at Road ATlanta--God help me!
olddrAGGER
Old Aug 30, 2008 | 08:27 PM
Base 04-05 models are under 2850# with light wheels and exhaust in Stock autox trim. A roll cage will obviously add weight, but under 3000# should be easy . I was in the low 2700# in STU trim.
Old Aug 30, 2008 | 09:30 PM
olddragger's Avatar
good news--i am going to search that old thread.
OD
Old Aug 30, 2008 | 11:23 PM
pdxhak's Avatar
Official Post Whore
FWIW I have a 2004 GT w/spare tire came in 3073 when corner balanced. I believe Nav is the only missing option from my car as well.
Old Sep 16, 2009 | 04:07 PM
jird20's Avatar
Mad for a Furai
If you do not care very much about meeting emission regulations during a cold start:
- remove the air pump, valves and tubing.
Sure it will trim about 16 pounds and the engine bay will look cleaner (and it will enable to place additional items in the engine bay (i.e. a little tank for fresh oil injection for the Richard Sohn adaptor).
The only problem with this is that the PCM shuts the engine off during cold starts when the pump is disconnected.
That being being fixed and you get less weight + more free space around the engine.
Regards
jird20
Old Sep 16, 2009 | 04:16 PM
Huh? No it doesn't.
You will get a CEL, but nothing "shuts off" or anything like that.
If you have a PCM reflash, you won't even notice anything different at all (other than the lack of a whine from the air pump on a cold morning).
Old Sep 16, 2009 | 04:52 PM
The weight isn't any where near 16lbs either as I recall, maybe 6 lbs just guessing
Old Sep 16, 2009 | 05:00 PM
Yeah, sounds about right.
Old Sep 16, 2009 | 05:04 PM
otherwise, get your f@t @ss to the gym ...
me too for that matter
Old Sep 16, 2009 | 06:01 PM
tmak26b's Avatar
My 06 base is exactly 3000lbs with FULL tank of gas and everything stock. With all the money you will need to lose that 150lbs and things you have to remove, you are better off selling that and buying a base model.........
Old Sep 16, 2009 | 07:52 PM
whoneedspistons's Avatar
anyone remove the sound deadening material in the cab? i know in other cars there was a significant amount of weight there....
Old Sep 16, 2009 | 11:55 PM
Zelse's Avatar
悪魔のR
15-20 pounds in the entire trunk , behind the rear passengers, and right behind the driver and passenger seats. At least it felt like it. :D
