Help wiring a V1 radar detector in my 8?
Old Aug 28, 2008 | 04:08 PM
RenesisNinja04's Avatar
Blue FTW!
Hey guys, use to have my V1 in my previous car and that had a light in the glove box... so was pretty straight forward to find a power source and run the wiring for a "hard wire" setup up the side of the window.
Which would be the best or at least some wiring tap options on the RX-8? Thanks.
-Rob
Old Aug 28, 2008 | 04:11 PM
laythor's Avatar
I zoom therefore I am.
Tap the cigarette lighter, run the wire behind the dash and either up the driver or passenger A pillar. I have my x50 run that way and the remote display mounted in the ash tray.
Old Aug 28, 2008 | 04:52 PM
Blue FTW!
Thanks I will take a look at that next time I go out to my car, sounds like it would work pretty good. Do you or anyone else know if there are any tappable wires on the passanger side under the dash?
Old Aug 28, 2008 | 05:09 PM
lopezian2004's Avatar
Master Shr3dd3r
Its not the passenger side, but its to the fuse box direct which, IMO looks clean as hell and also keeps you from messing with any lights by your glove box or whatever you are trying to do.
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-radar-detector-hard-wired-installation-8242/
Mine's wired from the fusebox up the weather lining to the ceiling and finally comes out directly on top of my rear view mirror.. from the outside you can't even tell i own a radar detector.
Old Aug 28, 2008 | 06:15 PM
1QWIK7's Avatar
Are you guys just stripping the coiled cable that comes with it and just using the power and ground wire?
Cause IIRC, theres 4 wires in that cord.
Or which one should i use?
https://store.valentine1.com/store/d...gory=partsdept
Old Aug 28, 2008 | 06:18 PM
rxaddict's Avatar
Check the DIY section. It's real easy to use one of the power wires for the map lights with the hardware in the V1 kit.
Old Aug 28, 2008 | 08:12 PM
1QWIK7's Avatar
I misplaced the hardware kit from my V1.
And i dont seem to find it on the website, thats why i added the link so someone can point it out for me.
Im blind, sorry lol
Old Aug 28, 2008 | 08:33 PM
laythor's Avatar
get this:
Direct-Wire Power Adapter Kit
Item 00030
Old Aug 28, 2008 | 09:04 PM
firebirdude's Avatar
User and Abuser
That's how I have mine hardwired. Works like a dream. And you can get the hardwire kits on eBay crazy cheap.
Old Aug 28, 2008 | 09:36 PM
Master Shr3dd3r
Im blind, sorry lol
Yeah get that hardwire kit on the V1 website. It comes with the wires already snipped if I remember correctly. For the fuse hardwire all you have to do is go to autozone and buy one of those cheapo 5 buck add a circuits to connect to your radar to the fuse box and somewhere else on your car.
i thought the maplight wire was only possible if your rear view was electric... maybe not i dont remember. but in any case i couldn't do it to the maplights b/c i have a standard rear view mirror. whatever you choose it will look good i'm sure haha. good luck
Old Aug 28, 2008 | 10:46 PM
rxaddict's Avatar
I have a base manual, so no homelink mirror. You can still tap into the maplight power but it is not switched like the powersource described in the DIY. In other words, you'll hafta turn the V1 on and off every time you get in and leave the car or it will run constantly. Not a big deal IMO, and over time, something that becomes as second nature as pressing the clutch pedal to start the car
Old Aug 28, 2008 | 11:36 PM
how / where are you mounting the radar?
Old Aug 29, 2008 | 10:56 AM
1QWIK7's Avatar
Originally Posted by laythor
get this:
Thanks for the info, ill get that.
I bought my V1 4 years ago brand new, came with the concealed display but i sold that concealed display a while ago and i misplaced the original box that had all the instructions and extra wires etc etc,.
I dont have an 8 but i have an FD where the dome light is right by the rearview mirror so i can get my 12V source from there. Its pretty easy to do, i just needed that wire kit.
Old Aug 31, 2008 | 07:59 PM
Blue FTW!
Thanks for all the advice guys, I was planning on mounting in on the pass side right under my strip of tint (same way I had in my other cars).
Do ya'll have a link for the DIY from the light/mirror area.. can't find it for some reason hehe. Thanks!
Old Aug 31, 2008 | 08:04 PM
User and Abuser
http://www.hi-impact.org/ryang/modif...valentine.html
I ended up ripping apart the cig lighter plug and doing my own soldering. Saved money on the hardwire kit and probably saved space. The hardwire kit for the Beltronics came with 6 miles of wire that could not be cut into. Cramming that all up in the lights wasn't any easier than craming the cig lighter adapter. Mise well save the money.
Old Aug 31, 2008 | 08:20 PM
NgoRX8's Avatar
countryjoycraft mount is the cleanest looking. right under the mirror.
Old Aug 31, 2008 | 08:30 PM
User and Abuser
They are awesome
*sorry for the large pic. Get a bigger monitor and run at a higher res. LOL *
Old Aug 31, 2008 | 10:39 PM
Looks like a very good job.
Old Aug 31, 2008 | 10:49 PM
+1 for the countryjoy mount, love where it holds the radar.
Old Aug 31, 2008 | 11:06 PM
NgoRX8's Avatar
haha huge picture! i probably do need a larger monitor after that.
gotta love that mount.
Old Sep 1, 2008 | 12:36 AM
imput1234's Avatar
I ♥ Drifting!!!
dude resize that pic, its freakin huge
Step by step on how to do it:
http://69.108.208.137/ryang/modify/r...valentine.html
Old Sep 1, 2008 | 12:41 AM
NgoRX8's Avatar
^shoulda been a diy on how to resize, lol
firebirdude posted a link to that hardwire diy already up above.
Old Sep 1, 2008 | 08:05 AM
Blue FTW!
Thanks for the DIY link fellas. Think I might do that since that seems pretty clean and simple enough. I don't have the V1 remote that he soldered in... so might just run the wire through the liner and suction cup the V1 right below my tint strip as planned. I think the V1 would probably work better suctioned on the glass/have better reception then on the sunblocker... but either way hehe.
Just out of curiosity where do you even by that mirror bracket ya'll posted a pic of. Saw the company, but not finding where to buy it. Thanks.
Old Sep 1, 2008 | 08:09 AM
User and Abuser
http://www.countryjoycrafts.com/350Z/valentinemount.htm
Old Sep 1, 2008 | 08:24 AM
Blue FTW!
Hey, thanks for the link on the bracket! Somemore quick Q's... how come your mount looks different? I see I would buy the plain mount, but it doesn't have the 2 screws at the bottom like yours does... did you do something different on your install? Also how does the V1 actually go on the bracket... does it just snap in place/slide through on the underneath... just wondering how secure it is (I know your detector is different just trying to see from the site)?
Also, I looked and they have user comments saying the stem size for the 8 is the 3/4 size. Unless I measured wrong I just went out and mine was about 2.75inches/3.14 to get the diameter. That being .875=23mm size stem. I have a touring model so not sure with the autodim and electronic type mirror if that makes a difference or not... which size was yours? Thanks.
