Rear license plate washer
Old Aug 27, 2008 | 08:59 PM
Dutch's Avatar
Hey guys,
Well I just got an 04 RX-8 and when I was trying to put on my plate I accidentally knocked back the washer into the rear bumper. Is there anyway to fetch it out? If not, how should I go about screwing the rear plate in?
Thanks guys
Old Aug 27, 2008 | 09:06 PM
snap-on's Avatar
Go to the local parts store and find the "help" rack. They sell plastic inserts you can snap into the hole.
like this..
http://www.napsupply.com/liplscandfa.html
The other one will fall out as you drive.
Old Aug 27, 2008 | 09:09 PM
NgoRX8's Avatar
it'll fall out. there's not much back there to make it stuck.
of course you can take off your rear bumper if you want to get it right now.
Old Aug 27, 2008 | 11:36 PM
kersh4w's Avatar
Hit & Run Magnet
the rear bumper isnt very hard to take off. should about 15 minutes.
Old Sep 7, 2008 | 11:54 PM
Dutch's Avatar
I think the hole is just too big for one of those plug in screws, anyone else have any other suggestions?
Old Sep 7, 2008 | 11:58 PM
NgoRX8's Avatar
too big? do you have a pic? it should fit fine.
Old Sep 8, 2008 | 08:57 AM
RK's Avatar
RK
It's Not Easy Being Green
Take off your rear bumper. It's really the only way. It takes about 30 minutes or so the first time you do it. Exhaust shrouds tend to be a little tricky to get off w/o breaking pins but the rest is a cakewalk.
Old Sep 8, 2008 | 12:51 PM
NgoRX8's Avatar
you won't need to take off the shrouds. fasteners inside wheel well, screws inside wheel well, fasteners near mufflers, screws behind taillights, license plate light. lift up slightly and pull outward.
Old Sep 8, 2008 | 01:39 PM
Dutch's Avatar
Am i required to remove the taillights as well?
Seems like such a hassel for something so small =\
Old Sep 9, 2008 | 08:35 PM
snap-on's Avatar
They sell them in the proper size.
Old Sep 9, 2008 | 09:19 PM
NgoRX8's Avatar
it'll be a good experience. haha
yes you need to remove the taillights as there are screws behind it holding the bumper up.
the taillights can be taken off by removing the tool storage panels, pulling the covers back, unplugging the four sockets on each taillight and the unbolting nuts.
JimmyBlack
273
Feb 10, 2020 10:23 PM
05rx8mazda
Nov 28, 2015 09:42 AM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
