smoking after oil change
Old Aug 25, 2008 | 07:01 PM
cjwaggs's Avatar
I have an 04 sport with a racing beat mid-pipe, rev8 exhaust and k&n intake... obviously i get a bit of smoke time to time with the mid pipe ... and flames .. that is to be expected, but after changing my oil and firing her up she was smoking a little extra than normal. the car was cold when started so she may have been running a little rich due to the temp. I might be overeacting but would appreciate any input. ps I do premix religiously.
Old Aug 25, 2008 | 07:03 PM
Where did you spill the oil
It should burn off if the filter and oil plug are tight....
Old Aug 25, 2008 | 07:07 PM
cjwaggs's Avatar
no spill.. the smoke was out of the exhaust..
Old Aug 25, 2008 | 07:42 PM
let it warm up. if it does not go away you have a problem.
Old Aug 25, 2008 | 07:50 PM
Check your air filter/ intake tube...if you filled it too fast it runs down the breather line into the intake.....it is a spill...just not one you will see unless you look.
It will likely burn off in a few days
Old Aug 25, 2008 | 09:36 PM
lilring's Avatar
Finally a MT
this happens alot when it gets colder and when condensation gets on your cat.. if it really starts to burn white smoke alot. then you have a problem.
if its like this.. then your rotary is gone...
http://myspacetv.com/index.cfm?fusea...deoid=41560605
Old Aug 25, 2008 | 09:50 PM
I8U's Avatar
I8U
^ He doesn't have a cat, he said he has a midpipe. It may have something to do with the temp, give it a couple of days. Should be fine.
Old Aug 25, 2008 | 10:45 PM
cjwaggs's Avatar
Swoope you were right ... after it got up to operating temp no more smoke, revved hard stil none, went for a 9000 rpm excursion.. still none... I think it had to do with being cold and running a bit rich... soon as she got up to temp perfect... man I love tnat mid pipe with rev 8 combo... wicked soundin!
Old Aug 26, 2008 | 02:03 AM
thanks for all the pollution ... cough, cough
Skyl3r
Dec 2, 2019 04:51 PM
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
talonhart2
Aug 26, 2015 04:14 PM
RotaryRider
Jul 20, 2015 07:05 AM
