Pic request of Dipstick
Old Aug 24, 2008 | 03:08 PM
Riken's Avatar
Drive it!
Does anyone have a pic of their dip stick? Should I have a F for full and L for low? Its weird to take out and I dont have the F and L.
Old Aug 24, 2008 | 03:27 PM
invasion08's Avatar
I believe you should see 2 lines with 3 dots in between them. Try to keep the oil level between the top dot and top line
Old Aug 24, 2008 | 03:33 PM
deadphoenix52's Avatar
meh.
http://www.finishlineperformance.com...7-04-1438b.pdf
Old Aug 24, 2008 | 06:36 PM
Riken's Avatar
Drive it!
Would I still get this out of warranty?
Old Aug 24, 2008 | 06:41 PM
jacobmullins's Avatar
where is your trans dipstick located???
Old Aug 24, 2008 | 09:02 PM
Nubo's Avatar
Lubricious
Umm... do you really need an "F" and "L"? The upper mark is "Full". The lower mark is "Low". The distance between the 2 is about 1.8 Quarts. At least this much is in the owners manual.
So, you have the older style without dots? No I don't think they will give you a new one. The bulletin was just to inform the technicians on how to interpret the gradations on what was a "new" style dipstick.
The dots do make it a bit easier to estimate the amount of oil needed to top off, since the range from F to L is non-linear.
You can "calibrate" your old dipstick if you'd like. I did mine....
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-calibrate-your-dipstick-81224/
Or, I'm sure Mazda will be happy to sell you a new one, with the dots.
Old Aug 24, 2008 | 09:03 PM
Easy_E1's Avatar
If you have an AT, it's on the left side of the intake manifold. It's Black .
Old Aug 24, 2008 | 09:44 PM
don't need an F or an L. just use the dots on there to measure the oil level
Old Aug 24, 2008 | 10:13 PM
NgoRX8's Avatar
The top dot usually means full.
Old Aug 24, 2008 | 10:21 PM
Riken's Avatar
Drive it!
no dots on my dipstick.......
Old Aug 24, 2008 | 10:44 PM
ken-x8's Avatar
Yeah - you've got an '04, before the new stick. You can add marks, like Nubo described. Or you can buy the new style stick for something like $10 to $15.
Old Aug 24, 2008 | 11:35 PM
simplyphp's Avatar
Or you can just look at the lines and figure it out, it's not that hard.
Old Aug 25, 2008 | 05:27 AM
Riken's Avatar
Drive it!
Talking
lol yeah I think I can figure that out, but what I was getting at was that the dipstick I have is weird the way it goes in.
Old Aug 25, 2008 | 07:28 AM
Riken's Avatar
Drive it!
on a side note, I did my oil change last night, I usally buy the Castro GTX and take it to a shop to change the oil for me since is right next to my job. So I changed the oil and in the manual it states 3.7 Qrts. I put in 4.5 Qrts and after driving to work about 35 miles I get an oil light, I was like WTH. So I added another half qrt in. I did jack up the car from the left and then the right and had it flat for like 20 minutes, and im also using the bigger Mobil 1 1010 filter. Is this normal?
Old Aug 25, 2008 | 07:47 AM
alnielsen's Avatar
Either your keyboard is missing an L or this is a brand of oil I have never heard of.
Old Aug 25, 2008 | 07:51 AM
mulkio's Avatar
Under-prepared
nah , that is an oil company out of cuba
Old Aug 25, 2008 | 07:55 AM
expo1's Avatar
He's as bad as Can
You can add them with a drill.
Old Aug 25, 2008 | 08:23 AM
Riken's Avatar
Drive it!
lol sorry was typing from my cell. I missed the L.
Old Aug 25, 2008 | 01:50 PM
Nubo's Avatar
Lubricious
Could you be more specific about this weirdness you are getting at? You still haven't gotten there.
You don't say whether you checked the dipstick at any point in this or if you did, what was the reading? The amount drained can increase if you jack up one side, which sounds like you did. And also the larger oil filter will of course take more oil. So I'd say that the 5 quarts you used sounds reasonable given your circumstances. When changing, it's a good idea to top off, start the car briefly to check for leaks, then shut down and take another reading and top off again. This will take care of the amount captured by the filter, instead of driving around and getting the oil light. Not quite as big a deal with the tiny OEM filter
Old Aug 25, 2008 | 02:01 PM
Riken's Avatar
Drive it!
Thats the thing when I look at the dipstick its wet all over not giving me a right reading. Weird in the way it goes on, I have to twist and turn for it to go in right, maybe is just me.
Old Aug 26, 2008 | 01:27 AM
Nubo's Avatar
Lubricious
The dipstick does have to bend a little because access to the location is tight; mine's taken on a slight permanent bend. And does take a little getting used to seating it fully in the tube so that the rubber/plastic bit gets seated home. Less a matter of twisting than of moving the handle a bit to find center.
It's a little easier to get a reading if you wipe it down first and then check again. The revised dipstick, in addition to the extra marks, is a little thinner. Don't know if that helps. My old-style dipstick got a lot easier to read when I sanded off that brown (paint? anodizing?). Heck of a lot more contrast between amber oil and silver, than amber oil and *amber* paint! Just make sure to finish sanding sand cross-wise, not lengthwise.
Contrast is your friend:
Old Aug 27, 2008 | 01:00 PM
Riken's Avatar
Drive it!
Thanks for the info Nubo
Jst4fun
Apr 17, 2021 07:43 AM
Jst4fun
Mar 5, 2021 07:16 PM
Rx8 VA Guy
Jun 4, 2016 12:42 AM
archon
Oct 1, 2015 06:08 AM
FubarI33t
Sep 28, 2015 08:45 PM
