Lost horsepower
Old Aug 19, 2008 | 03:07 PM
brandon1231's Avatar
Lost horsepower
Just bought a 2004 rx8. It runs great and I knew it was supposed to have around 220-230 horsepower so I took it to a dyno. It dynoed at 154hp. How can I get that lost horsepower back??
Old Aug 19, 2008 | 03:11 PM
NgoRX8's Avatar
your confusing crank hp with wheel hp.
average is about 170 to 180 whp.
may want to check your ignition coils too.
Old Aug 19, 2008 | 04:06 PM
yup, the hp figures you read on window stickers or reviews are always measured at the crank.
Drivetrain loss gives you wheel horsepower.
Stock 8's do 170-80, some go as high as 200hp but it all depends on what type of dyno.
mustang dynos read lower then dynojets.
Old Aug 19, 2008 | 04:27 PM
NgoRX8's Avatar
true, if your reading is accurate and it was a mustang dyno, it looks right.
Old Aug 19, 2008 | 04:32 PM
I don't know why people are SO obsessed with HP figures.
The car was fun as hell when you thought it was 230 hp, right?
now some machine tells you it's only 154 hp.
Does that make the car any less fun?
Old Aug 19, 2008 | 04:43 PM
shaunv74's Avatar
Power!!
Show us your dyno sheet, what your dyno was and then go do a search on dyno plots for others here and see what a normal dyno plot looks like.
154hp is a useless number to us by itself.
edit: That being said there are two common culprits that rob hp on the RX8. Bad ignition coils and a bad cat. converter. The dyno plot will show if you have either of these problems.
Old Aug 19, 2008 | 05:24 PM
RWagz's Avatar
Piston-free 07.11.2007
I can't remember at the moment exactly what it is, but isnt there an issue with
the DSC system and dynos that can also cause issues? I remember reading on here people commenting about disconnecting sensors on the rear wheels while on the dyno.
Old Aug 19, 2008 | 05:32 PM
nope.
All you need to do is hold down the DSC button to disengage it.
Old Aug 19, 2008 | 05:34 PM
RWagz's Avatar
Ok, just thought I'd throw it out there. Either way I don't have to worry about it - I have a base '05 and therefore am DSC-less.
Old Aug 19, 2008 | 05:36 PM
Brettus's Avatar
Boosted Kiwi
according to some on here - it is very dangerous to drive without DSC - you should have crashed by now
Old Aug 19, 2008 | 05:57 PM
twice if your car is silver
Old Aug 19, 2008 | 06:54 PM
RWagz's Avatar
I'm a firm believer in placing the blame on the driver, not the car.
Old Aug 19, 2008 | 11:10 PM
Unless it's Silver.
Old Aug 20, 2008 | 12:52 PM
turbo.
Old Aug 20, 2008 | 10:53 PM
Access Port from MM
Old Aug 20, 2008 | 11:06 PM
access Port will NOT get you that kind of HP from an N/A
Old Aug 20, 2008 | 11:08 PM
mu ha ha... proven to get 25 more poines at the wheels.
Old Aug 20, 2008 | 11:09 PM
Old Aug 20, 2008 | 11:11 PM
You forgot your Dyno run already?
Old Aug 20, 2008 | 11:18 PM
nope, I still remember beating almost every other M/T there.
I have more mods though...
Old Aug 20, 2008 | 11:58 PM
silver + no dsc = gg
Well known Rx8club.com myth ...
Old Aug 21, 2008 | 07:52 PM
Cattywampus's Avatar
Turbos blow!!
Smell that? Smells like grilled troll
crimson809
Aug 14, 2016 10:03 PM
XianUnix
Sep 29, 2015 03:48 PM
p8ntman442
Sep 23, 2015 09:18 PM
