Synchro Problems (any one else?)
Old Aug 18, 2008 | 12:45 PM
Tree_Frog's Avatar
hello.
I was just wondering if anyone else had synchro problems with their 8's.
and would like to compile a thread concering this issue. so if you could post that would be great.
Year of Rx-8:
driving style (commute, aggressive, both):
Gears Grinding:
Type of Transmission Fluid (dino or syn):
Brand of fluid:
Warranty denied or approved:
thank you
Old Aug 18, 2008 | 01:20 PM
jones75254's Avatar
(back when i had probs)...
2004 w/ 40k miles. (bought it w/ 38k miles on it)
City/commute type driving w/ occational aggression.
3rd and 4th gears grinded at 6k rpm and above shifts.
Fluid: OEM
Approved warranty work: Both gears replaced
Old Aug 18, 2008 | 10:05 PM
My God.......there must be 50 threads on this
Old Aug 18, 2008 | 10:37 PM
SilverHokie's Avatar
I'm Delaware Fast
Yes...there are 50 threads on this. But I feel bad cause I was one of them.
if you search, a guy did the same thing as you. Collect info and whatnot on people's cars. Problem is...dealer wont give a ****. Its not a problem unless Mazda says it is.
Old Aug 19, 2008 | 12:43 AM
Tree_Frog's Avatar
there are 50 threads on this but im looking to organize it and consolidate it.
also i did find the thread of another member doing the same thing. I asked him for the list but he no longer has it.
im compiling this list to prove that the synchro problem is large and this is probably not an isolated incident. its to help build a case.
thanks
Old Aug 19, 2008 | 05:04 AM
nate340's Avatar
Year of Rx-8: 2004
Mileage: 80 000km
driving style (commute, aggressive, both): aggressive
Gears Grinding:5-6
Type of Transmission Fluid (dino or syn):dino
Brand of fluid: what ever the dealer puts in?
Warranty denied or approved: approved
Old Aug 19, 2008 | 12:33 PM
PSUGreySreet's Avatar
i dont have the paperwork in front of me, but what warranty would cover this work? 8yr/80,000? or original factory?
edit: And I apologize, I don't mean to hijack this thread by asking a question, but it certainly pertains to this. Often lately, I'll rev out from stop to 9k in 1st, go to shift into second and I'll grind it occasionally. Now I don't know if it's b/c I'm too quick to let off the clutch and don't have the gear in all the way before letting out; or if it could be something like synchros. It doesn't always happen, which makes me thin I may just be too quick sometimes, but it def. feels not as smooth as it once was going into 2nd.
Old Aug 19, 2008 | 05:14 PM
nate340's Avatar
5yr / 100 000km drivetrain i believe. while i was shopping for 8's i test drove 1 that was grinding between hi rpm up shifts from 1st-2nd.
Old Aug 19, 2008 | 06:45 PM
thanks for the response. I'm at 72,000 miles & change right now on mine so the orig warranty is out, but if the extended Mazda granted warranty will take care of it, then I may take it in soon. Like I said, it only happens when I really try and take a quick shift from 1-2 (it seems that 2nd gear is always the gear I tend to miss). Sadly, it may just be user error and I've really been watching...
more opinions are surely welcome...
Old Aug 19, 2008 | 09:31 PM
nate340's Avatar
try a high rpm down shift from 2nd -1st make sure the clutch is to the floor shift nice and smooth and see if it still grinds
Old Aug 20, 2008 | 01:38 AM
Jasonawojo's Avatar
Year of Rx-8: 2004
Mileage: 58,000
driving style (commute, aggressive, both): Mostly city, occasionally agressive.
Gears Grinding: 5th. Jolting/roughness in a few others, as well.
Type of Transmission Fluid (dino or syn): Synthetic
Brand of fluid: Redline MT-90
Warranty denied or approved: Approved for 5th gear replacement. Made other issues worse, though. Might have been the dealer's OEM fluid.
Old Aug 20, 2008 | 08:29 AM
I'm Delaware Fast
See? I don't think it was the fluid that did it. That stuff you had in it before was just covering up the major problems. Your transmission needed more work.
Old Aug 20, 2008 | 08:37 AM
jones75254's Avatar
Could be clutch pedal bracket assembly goin bad? That or your synchros/gears are simply in the beginning stages of going bad. When mine first started i thought i might have just been doing something wrong with my driving but that wasnt it, its something mechanical for sure, you will just have to wait until u can duplicate it for the warranty work to be done.
Old Aug 20, 2008 | 11:33 AM
thanks guys!
Old Aug 20, 2008 | 01:35 PM
Tree_Frog's Avatar
i too am running redliner mt-90 synthetic oil
and just want some good solid evidence that it wasnt the fluid that messed stuff up
Old Aug 26, 2008 | 06:15 PM
Tree_Frog's Avatar
theblinkof
Oct 4, 2023 05:24 PM
Shankapotamus3
Mar 14, 2021 03:53 PM
Zube6115
Sep 30, 2015 12:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
kody59
Sep 28, 2015 03:43 PM
