ignition solution
Old Jul 31, 2008 | 03:23 PM
VS8's Avatar
VS8
4 Cylinder Rotary
ignition solution
what does the mazsport ignition solution actually do? how does it work and are the power gains
Old Jul 31, 2008 | 03:39 PM
Rotore_787's Avatar
I kill Vtec's
you don't really upgrade ignition unless you are going onto major power upgrades or you want better throttle response. i dont think you can actually gain any power of a ignition ugrade just better throttle response.
Old Jul 31, 2008 | 03:47 PM
VS8's Avatar
VS8
4 Cylinder Rotary
so would nitrous count
Old Jul 31, 2008 | 04:03 PM
invasion08's Avatar
The Dyno does not lie
Old Jul 31, 2008 | 04:41 PM
Rotore_787's Avatar
I kill Vtec's
No and heres a rule most racers go by if it goes past 375hp then its time for a ignition upgrade or if you want better throttle response then upgrade it could shave a second or of your track time but for actual power under 375hp i dont think so.
and that car had more then ignition done to it trust me
Old Jul 31, 2008 | 04:47 PM
paulmasoner's Avatar
Asshole for hire
haha, thats funny cause in this car you run into spark blowout around 330whp.....
even at stock power levels the ignition is only adequate at best
Old Jul 31, 2008 | 04:53 PM
Easy_E1's Avatar
^That's why I use the BHR Ignition solution.
Old Jul 31, 2008 | 05:12 PM
Asshole for hire
and i will be fairly soon. i wont have much choice, if you know what i mean
Old Jul 31, 2008 | 05:49 PM
Rotore_787's Avatar
I kill Vtec's
my corolla, s13 and 1.8 didnt need it till they hit 375hp. Honda needs it at 400hp or more. and i guess its 330hp on this one hmmmm thats kinda low dont you think?
Old Jul 31, 2008 | 06:10 PM
mysql's Avatar
Doppelgänger
The stock coils don't stand up to the heat well. They degrade over time.
Assuming your stock coils are functional and not wearing down, you can expect no gain by switching to different coils unless you're well over 300 whp. So anyone who isn't FI, don't expect much.
However, if you switch, your car can run temporarily lean causing your car to gain a bit of power till the PCM learns and readjusts. After that, you can expect the car to perform normally again.
Basically, if you're 330+ whp, you would need to upgrade.
If you're not over 330 whp, then upgrade if you want to escape from upgrading coils once every 1-3 years.
The BHR coils don't need an ignition box and don't need tuning to make work, unlike the Mazsport ones.
Old Jul 31, 2008 | 06:26 PM
Rotore_787's Avatar
I kill Vtec's
isn't that basically what iv'e been saying...
Old Jul 31, 2008 | 06:28 PM
mysql's Avatar
Doppelgänger
everyone says everything increases throttle response.
new intake? more throttle response.
throttle body bypass? more throttle response.
ignition coils? more throttle response.
new catback? more throttle response.
catless midpipe? more throttle response.
v-tec sticker? more throttle response.
getting punched in the neck? more throttle response.
Old Jul 31, 2008 | 06:35 PM
TThell's Avatar
would this not provide more complete combustion of the fuel charge, since it is suppose to create a larger spark and hopfully a larger flame front
I may be making assumtions here but I was hoping it would provide a little better overall combustion of the fuel that is being added and maybe a 1-2 Mpg increase
Old Jul 31, 2008 | 06:37 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Jason, that tuning part is really only true for FI right? NA doesn't require any tuning with the Mazsport......correct?
Old Jul 31, 2008 | 06:38 PM
Rotore_787's Avatar
I kill Vtec's
[QUOTE=mysql;2576599]everyone says everything increases throttle response.
thats the only one i saw that'll actually increase throttle response.
if you want more throttle response jus upgrade throttle body, ignition components, clutch/flywheel.. thats basically it
if you want a bit more power then go with intake, mid-pipe, cat delete or hi-flow cat and exhaust.
Old Jul 31, 2008 | 06:40 PM
whoneedspistons's Avatar
mazsurfer you are correct
Mazurfer's Avatar
Don't take this as gospel, but I just filled up today after 250 miles on a tank, my previous record was only about 230 miles or so. No driving habit or mod changes, so it's not real scientific and I'm not really sure yet.
One other thing I've noticed besides just a little throttle response is that my exhaust tips don't have nearly the oily deposits on them as they used to. I'll bet I wipe them off maybe once a week where I used to do it every single day.
Old Jul 31, 2008 | 06:43 PM
Mazurfer's Avatar
^...........I assume you mean about the no tuning if you are NA on the Mazsport?
Old Jul 31, 2008 | 07:12 PM
mysql's Avatar
Doppelgänger
In theory, but several have reported loss of top end power. Do some searches.
I have yet to see a plausible reason for paying more for a system that may need tweaking to get working properly. You're dropping $599 for what exactly?
Old Jul 31, 2008 | 07:45 PM
tajabaho1's Avatar
Destroying Threads
oh is it 600? I thought it was 500.
Old Jul 31, 2008 | 07:53 PM
Asshole for hire
here i'll fix it:
if you want a bit more power then go with cat delete or hi-flow cat(maybe) with tuning
the intake and cat-back are practically useless for power as you cant consistently get the same results for anything more than 1-3hp from any combination
Old Jul 31, 2008 | 07:58 PM
mysql's Avatar
Doppelgänger
I guess you can think of $599 as $500 if you wanted.
Old Jul 31, 2008 | 08:00 PM
Easy_E1's Avatar
All I know is it's a lot more than the soon to be released BHR Ignition Coils.
Old Jul 31, 2008 | 08:01 PM
invasion08's Avatar
My Mazsport Ignition Solution works great for my set up
Old Jul 31, 2008 | 08:26 PM
Rotore_787's Avatar
I kill Vtec's
that was the whole point of me saying abit more power not that much and i was talking about a catalytic converter not a cat-back my bad. OR YOU CAN DO MY FAVORITE NO CAT OR NO MUFFLER JUST A STRAIGHT PIPE BACK! it sounds cool but it illegal
