Transmission problem someone tell me something PLEASE
Old Jul 30, 2008 | 06:05 PM
YELLOW MONSTER's Avatar
FAST 8
Ok i have a 04 manual Rx8 and im having problems with my transmission.
When the car is in "N" it makes a weird noise as if the cluth is rubbing aginst something when I push the clutch down the noise stops.
2nd problem the car will not pull in 1st. If I put it in 1st gear it will stay but when I ease off the clutch it falls out of gear and makes a gringing noise in the process of falling out.
3rd problem the car will not stay in reverse either same problem with it as with 1st gear.
4th problem the car makes a clutch rubbing noise in all gears and im wondering is this my clutch or my transmission or some other part. If anyone knows anything about this problem please let me know..
Old Jul 30, 2008 | 08:25 PM
lshu's Avatar
Driving makes me :)
1st issue sounds normal. The sound comes from the clutch engaging the free-spinning layshaft in the transmission (see article on transmissions on howstuffworks site to see how this works). The transmission in this car is really close to the passenger cabin, so the noise is louder than average car. Use a synthetic gear oil (e.g. Redline) to help with the sound and transmission smoothness.
2nd problem sounds like a potential problem, unless you just aren't pushing the stick all the way in gear. Does this happen all the time or just sometimes? On occasion I can't get the stick fully into first (dog teeth not lined up properly), so I just put in neutral, clutch out, then try again.
3rd problem is a known quirk with this car. My fix that works 100% is to put the gear in reverse, then hold the stick down as you release the clutch slowly. You will feel the stick pop into place.
4th issue is probably just the usual transmission noise. As stated this is normal and can be made better with synthetic gear fluid.
Old Jul 30, 2008 | 10:57 PM
04RX8man's Avatar
Rotary Powered Countryboy
perfectly said.....
Old Jul 30, 2008 | 11:01 PM
FAST 8
I cant get the car to stay in gear and Ive tried so many times to take it out and put it back in gear but it just wont work could it be the clutch or something?
Old Jul 31, 2008 | 02:23 AM
reverse going bad is a sure sign that a new trans will be required soon, this is not the same issue of it not going in and requiring a double clutch ... combined with the noise it' likely extreme internal wear
Old Jul 31, 2008 | 03:47 AM
Eight's Avatar
^ yes new trans or a rebuild soon...
Had same problem with the gears falling out(not literally) and grinding on my honda, replaced the worn synchros and and ring spring and its smooth as new...
Old Jul 31, 2008 | 10:04 AM
04RX8man's Avatar
yeah if it just wont' stay in prob synchro's but trust me don't pull too hard on the shifter or you will bend your shifting forks....been there done that not fun...trust me
Old Jul 31, 2008 | 01:59 PM
FAST 8
The things thats bothering me is that it will pull in 2nd,3rd,4th,5th,6th but makes a lil clutch noise, so im guessing it isnt the transmission, well thats what im hopeing at least
Old Aug 2, 2008 | 09:31 PM
mrmazda7's Avatar
I have heard of many of these transmissions not lasting past 30k miles
Old Aug 3, 2008 | 12:05 AM
and you heard that where?
Old Aug 3, 2008 | 09:48 AM
mrmazda7's Avatar
Trans
Kevin Landers has said that they have syncro issues with low miles.
Also, two local dfw owners(Mike and Jamal) have each told me there trans have syncro issues with less than 40k.
Old Aug 3, 2008 | 04:16 PM
there have been some issues, but the sky is not falling..
Old Aug 4, 2008 | 03:10 PM
I'm on #3 and it has a 3rd gear synchro grind, hoping to pull it down soon and make the fix, so yeah the sky isn't falling, there's just a gaping hole in the ground down to hell ...
definitely the weakest part on an RX-8
Old Aug 14, 2008 | 04:01 AM
luv4eternity's Avatar
Low is a lifestyle
Same Problem And Worse
i have the EXACT same problem ...and ALL my gears grind when im trying to shift in to the next gear or drop a gear ; including reverse.... would it be the transmission problem or clutch ? because i went to mazda today and they say it cost $140 to look at it ...I was like "WTF...isnt my car still in extended warranty ?" ...they said they will cover it ONLY IF it is a internal transmission problem .....SO , if its a clutch problem , they wont cover it because its a wear and tear item ....Anyone can tell me what problem it would be ? Would it be the Transmission or Clutch ?
Old Aug 14, 2008 | 04:06 AM
sorry,
your car is the hurricane hunter..
Old Aug 14, 2008 | 10:22 AM
Socket7's Avatar
ಠ_ಠ
Your transmission is shot. The shifter should never pop out of gear. Could be a long while before it fails outright though.
The RX8 tranny is pretty good. but it's a sports car, so it's designed to be lightweight, not bulletproof. If you abuse it by shifting to hard, shifting without the clutch, etc, you can and will damage it.
Mane
Nov 20, 2015 12:16 PM
vapor2
Sep 21, 2015 01:36 AM
ed0128
Sep 9, 2015 04:50 PM
Anthony Kevin
Sep 7, 2015 07:36 PM
