Amps????
Old Jul 22, 2008 | 11:51 PM
gtballa14's Avatar
Amps????
Im looking to install two 10" jl audio w6's in my 8. I am looking at the jl 500/1 and the 1000/1 amp but im not sure which one to get. I dont want to overpower the subs but I do want them to play at their full potential. Thanks.
Old Jul 23, 2008 | 10:10 AM
BBQdDude's Avatar
BBQ Smoker Addict
You could always go with the higher wattage amp. If you find it cutting out, due to pushing too much to the woofer, you could dial the gains back to compensate.
What are the subs rated at?
Take care,
Brian
Old Jul 23, 2008 | 12:08 PM
Socket7's Avatar
ಠ_ಠ
Compare the RMS of the subs to the RMS of the amp. If the RMS of the subs is roughly equivalent to the RMS of the amp, you'll be just fine.
Having more power in the amp is not a bad thing. It will let you run lower gains and that theoretically means you'll have less noise.
You'll have to do some maths and choose a wiring strategy (parallel or series) to figure out the actual RMS of the speakers, since you're planning on running them both off a mono amp.
Old Jul 23, 2008 | 12:28 PM
Davey's RX-8's Avatar
Red headed stepchild
I imagine you could go with either, though if you really want noise obviously the 1000/1 is more powerful. Before getting a 12w7 I used two Boston 12's with my 1000/1 and they just soaked up the power. I would imagine two 10w6's should do so as well.
Old Jul 23, 2008 | 04:32 PM
jstkilntim's Avatar
resU deretsigeR
Go w/ the 1000/1. The W6s will love it. Tune the system properly and you will love it too.
Old Jul 23, 2008 | 07:42 PM
gtballa14's Avatar
Thanks guys, im gonna go with the 1000/1 setup.
nadodave
Aug 28, 2019 05:55 AM
Learners_Permit
Sep 27, 2015 07:38 PM
juicemantwon
Sep 26, 2015 12:30 PM
just1jack
Sep 9, 2015 04:45 PM
