Need Help setting up my boost controller!
Old Jul 20, 2008 | 12:03 AM
TurboEight's Avatar
Booost.
I guess I posted in the wrong place before...
hopefully I'll get some help in this section..
I just installed the Greddy E-01...
It seems pretty to use when I read some threads on here suggesting on how to set-up the controller
Current setup
LO:
Set: 50%
Gain: 0
Start boost: 5.2
Baseline WITHOUT contoller on is around 5PSI
So now I should be netting 7.5 PSI correct?
Ilde without AC: ~-7.0 to ~-7.5 PSI
IDLE with A/C: ~-7.5 to ~-8.2 PSI
Coasting in-gear: -11PSI
ok..so am I on the right track?
I am getting a fluttering sound...sounds like a valve opening and closing really fast.
and My limiter is OFF.
whats wrong.
next...I NEED this to monitor
Where can I tap into the RPM signal coming from the ECU.
the E-01 askes for that when installed to log my RPM/Boost.
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
titaneum_grey
Sep 6, 2015 10:21 PM
20b-3rotor
Sep 2, 2015 08:54 AM
