Any tips for how to launch?
Old Jul 16, 2008 | 11:00 PM
lamarvannoy's Avatar
Wink Any tips for how to launch?
I just took my car to Raceway Park New Jersey and ran a terrible time due to massive wheel spin. What RPM should you launch at? I was Launching at about 4 grand to avoid bogging but ended up with way too much wheel spin. Is there a happy medium? Any techniques? I also turned the traction control off for one run due to the loss of power the first run if that helps... i dunno
Old Jul 16, 2008 | 11:17 PM
TheWulf's Avatar
My 8 looks like a Smurf
Well for one if you turn off traction control you will definitely get more wheel spin. It's a trade off. Where you should launch depends on your mods and your tires... play with it with and without traction control and see what works for you.
Old Jul 17, 2008 | 12:25 AM
lower the air pressure to ~ 24 psi in the rear..
feather the clutch at ~ 4.5k rpm.. if you dont know what feather means.. search feather and motocross..
it does abuse the clutch, but is effective..
or the other option if you are really really serious. drop the clutch at ~ 7 k rpm.
it is faster, but a lot more money.. clutch will be ok, but is sucks to be the transmission.
life is a risk.
btw, hold the tc / dsc button down for 7 secs.
Old Jul 17, 2008 | 12:38 AM
Easy_E1's Avatar
I just step on the gas. Oh snap I have an AT.
Never mind.
Old Jul 17, 2008 | 12:59 AM
TopGear8's Avatar
mkuhnracing.com
^Haha that made me laugh
Old Jul 17, 2008 | 06:30 AM
chancejat's Avatar
Drive it like u stole it!
depends on the track prep as well....try doing a nice burnout b4 you line up....it should make the tires stick alot better.....when i go to the 1/8th mile i launch at 6-7k rpms and get 2.0-2.1 60's.....
Old Jul 17, 2008 | 07:34 AM
Mr.&Mrs.Magic's Avatar
I am under the impression that unless you are running some sort of sticky tire that a burn out is a waist of time?? with no burn out very little wheel spin and a 6k quick slip we are getting 2.3??'s
swoope-just how much differance would letting the air from 28 to 24 make? the road coming into the drag is beyond freaking horrible.
Old Jul 17, 2008 | 08:56 AM
416to212's Avatar
Utopia Taco Bell
For drag racing I have a problem with either spinning too much or getting massive wheel hop or both where it goes from spinning to wheel hop....
I also agree that burning out with a street radial tire is a waste of time. In fact I feel that building up heat in a street tire turns it greasy not sticky....
Old Jul 17, 2008 | 12:44 PM
What will happen if i hold the t/c button down for 7 seconds?
Old Jul 17, 2008 | 12:51 PM
Decat's Avatar
It turns both tc and dsc completely off, basically no more help at all from mr computer keeping those tires gripping.
Old Jul 17, 2008 | 01:02 PM
If you just hit the trac button all it does is turn off the dsc which will do nothing for you in a straight line, but if you hold it down till you see the light with the car and little squiggly lines then you have turned off the actual traction control. unfortunally you can not turn it back on till you kill the car.
Old Jul 17, 2008 | 01:05 PM
how did you get massive wheel spin if you didn't know you had to hold down the trac button?
Old Jul 17, 2008 | 04:20 PM
chancejat's Avatar
well thats how i do it and it works just fine....spinning cleans the tires...
Old Jul 17, 2008 | 05:19 PM
if you simply push the dsc button it says dsc off in the dash and the tires will spin all day so i have not idea what holding it for 7 seconds does. i just tried it and it made no difference. i have an 05 gt manual so i dunno if that makes a difference. maybe the t/c was set up different on 05's or somethin
Old Jul 17, 2008 | 08:37 PM
Also... i wanna talk about times cuz the best i got was a 15. Whats up with that? i have a k&n typhoon and a borla exhaust, axial flow short shift... is that bad? im not too sure what they are supposed to run
Old Jul 18, 2008 | 05:04 PM
StrokerAce's Avatar
My personal choice would be a Saturn V
Old Jul 24, 2008 | 07:51 AM
Outkast187's Avatar
Thats about normal for those mods, pretty quick for a import daily driver. About the same as a mid 80's vette.
R3Dream
Mar 7, 2019 09:11 AM
poacherinthezoo
Aug 3, 2016 11:01 PM
titaneum_grey
Sep 16, 2015 11:51 PM
Jonesboy2398
Sep 13, 2015 05:28 PM
