B-Stock Class Allowable Mods
Old Jul 11, 2008 | 12:33 PM
dothackRAVE's Avatar
<3 Rotary
Did some searching on Google..., but what I found was rather confusing, and wasn't clear on what I'm allowed/not allowed to do...
So I figured I'd just ask straight up. What can I do?
Old Jul 11, 2008 | 12:35 PM
SteveB's Avatar
Rotary Newbie
Tires. Front Sway bar. Catback. Intake filter. Shocks. Lighter wheels but have to be the same size.
Old Jul 11, 2008 | 12:39 PM
iaus10's Avatar
0110100001101001
http://scca.com/documents/Solo%20Rul...lo_Rules_2.pdf
Section 13 is the one you want.
<3 Rotary
Shocks as in springs? I was looking at some KONIs, but then got worried that the spring rates might not match with the dampening rates.
Front sway bar..., as in the chassis stiffening on the bottom, or the strut bars at the top?
Old Jul 11, 2008 | 12:47 PM
chiketkd's Avatar
Row faster, I hear banjos
Shocks only -- so konis are okay but you must use the stock springs with them.
The front swaybar runs below the engne bay and connects the chassis to the lower A-arm on each side iirc. The strut tower bar runs along the top of the engine bay (NOT allowed to change this).
Old Jul 11, 2008 | 12:48 PM
edj's Avatar
edj
RX8 Steering Wheel Spacer
shocks only; you cannot replace the springs
front sway bar connects to the lower control arms of the suspension.
you may not change the strut bar at the top shock mount.
Old Jul 11, 2008 | 01:12 PM
mwood's Avatar
Two most important items:
Tires (DOT R)
Alignment
Also, if you use the SEARCH function on this board, you not only will find a ton of set up information, you will also avoid the wrath of baghead...
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
gwilliams6
General Automotive
60
Nov 3, 2015 02:50 PM
FubarI33t
Sep 28, 2015 08:45 PM
TheRedRotor
Sep 12, 2015 07:42 AM
