Lighting up the shift knob?
Old Jul 6, 2008 | 09:51 PM
lopezian2004's Avatar
Master Shr3dd3r
Lighting up the shift ****?
Anybody thought of doing this? Is it even possible? I'd like to get a small blue LED underneath the shifter just to add a little something cool... maybe hook it up to the running lights or just leave it on regularly. Any help?
Old Jul 6, 2008 | 09:55 PM
alnielsen's Avatar
There used to be a lighted **** available. If I remember correctly, people had problems with it.
Old Jul 6, 2008 | 10:09 PM
[]RhOdEs[]'s Avatar
I don't look at my shifter when i'm driving, no need for lights.
Old Jul 6, 2008 | 10:31 PM
paulmasoner's Avatar
Asshole for hire
you could do it if you really wanted to. you could basically come out with a replication of the lighted shiftknob that i think is JDM(?)
but honestly if your asking if it can be done and for ideas, its prolly REALLY not worth it as it wont be as simple as buying an led and a piece of wire and plugging it into something then glueing the cap back on the shifter
just buy the one thats sold already, it's something ridiculus like 200-250 bucks, but it'll be cheaper than all the time and effort your gonna put into converting your OEM one
Old Jul 6, 2008 | 10:43 PM
yeah, the original illuminated shift **** had issues with the weak soldering job. Many users complained that the lighting did not last long.
Would be a great mod were it not soooo expensive.
Old Jul 6, 2008 | 11:16 PM
Master Shr3dd3r
Haha so not as simple as just running a wire from the **** to your running lights wire? (assuming you want it that way)
I am definitely not good with how wiring works at all
Old Jul 7, 2008 | 09:55 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
They changed the wiring on the JDM illuminated **** and mine has been in for over two years with no issues. Also....Pollack did do a DIY where he showed how to change out the red LED to a blue, but I just never got around to doing it yet.
The site appears to be somewhat broken at the moment, but this link might get you close, but you'll have to wait for the site to get fixed.
http://www.mazdaparts.com/
Old Jul 7, 2008 | 11:34 AM
jin kazama's Avatar
...and The Red Baron
look here !
Attached Thumbnails Lighting up the shift knob?-1.jpg   Lighting up the shift knob?-2.jpg   Lighting up the shift knob?-3.jpg   Lighting up the shift knob?-4.jpg
Old Jul 7, 2008 | 11:35 AM
jin kazama's Avatar
Attached Thumbnails Lighting up the shift knob?-k1.jpg   Lighting up the shift knob?-k2.jpg   Lighting up the shift knob?-k3.jpg   Lighting up the shift knob?-k4.jpg   Lighting up the shift knob?-k5.jpg
Old Jul 7, 2008 | 11:40 AM
jin kazama's Avatar
By Mavros piravlos
Attached Thumbnails Lighting up the shift knob?-k11.jpg   Lighting up the shift knob?-k12.jpg   Lighting up the shift knob?-k13.jpg   Lighting up the shift knob?-k14.jpg
Old Jul 7, 2008 | 01:21 PM
TheWulf's Avatar
My 8 looks like a Smurf
^^ woah... that is awesome... where can I buy this?
Old Jul 7, 2008 | 05:00 PM
Tamas's Avatar
Registered Lunatic
Interesting...
Old Jul 8, 2008 | 03:10 AM
Conundrum's Avatar
Wow... nice job... How do you remove the center shift pattern? I know I tried it and couldn't, end up scratched the silver trim piece instead
Old Jul 8, 2008 | 05:07 AM
VarneyMazda's Avatar
Northeast Pimpin'
Did you try heating it up?
Old Jul 8, 2008 | 08:41 AM
Mazurfer's Avatar
Do some searches if you get no answer. Pollack had a thread where he showed how to do it with pictures( I think). He was doing this to change the LED to blue, I think it involved heating it up slowly with a heat gun to soften the glue, then prying it up carefully witha very small intrument. Then it was just using super glue to hold it back down when done. Something about only glueing the edges so you didn;t mess up whatever pattern your shift **** has on it. Mine just has the normal 1-6 shift pattern that lights up. I'll see if I can find the thread.
Old Jul 8, 2008 | 08:50 AM
Mazurfer's Avatar
Actually, now that I found Pollacks DIY thread again. It appears as if he may have cooled it down to loosen the glue.
This thread is about how to basically install it, but eventually you can see it turns into how to get that top off and change the LED out.
https://www.rx8club.com/showthread.p...ted+shift+****
Old Jul 21, 2008 | 02:15 AM
Conundrum's Avatar
Originally Posted by jin kazama
look here !
The only thing I can't figure out at this point is how you manage to squeeze the wire to the side... between the **** body and leather without removing the leather.
Old Jul 21, 2008 | 02:44 AM
laythor's Avatar
I zoom therefore I am.
i'm using a vodoo piano black **** (no shift pattern)... i know where 1-6 and R are located without looking.
Old Jul 21, 2008 | 04:37 AM
Tamas's Avatar
Registered Lunatic
It's all about the looks, not that anyone would need the lighted **** to show where to shift.
WranglerFan
May 31, 2022 07:51 AM
WranglerFan
Nov 5, 2017 09:35 AM
Vedivan1
Sep 20, 2015 04:39 PM
erikcamacho15
Sep 12, 2015 11:23 AM
