Daily Revving to ~7k RPM
Old Jul 1, 2008 | 01:21 PM
bejackso's Avatar
I have heard that it is generally good to take the RX-8's Renesis engine up to ~7000 RPM once or twice everyday (prevents carbon buildup, other things I don't know off the top of my head but have heard before). Of course you would do this once the engine has been running for a little and is nice and warm.
Is it truly good practice to do this? What about redlining once or twice everyday? Or just taking it to 5k RPM?
Old Jul 1, 2008 | 01:29 PM
StealthTL's Avatar
Metatron
Even 5k, by itself, won't do any good.
You need a blast of foot-to-the-floor 'redline' wide open throttle to burn carbon and 'clear the pipes'. At 5k the third set of intake ports is still closed.
S
Old Jul 1, 2008 | 01:34 PM
It sounds like you're "so afraid" of revving it high.
Do you have any idea how Rotary engine works ?
5K wont do anything, just like Stealth said
Old Jul 1, 2008 | 01:51 PM
maxxdamigz's Avatar
Baro Rex
I specifically designed my drive home from work to incorporate some full run outs of second gear because it's fun. The maintenance benefits of it are somewhat secondary to me. When in a "sporty" mood, my RPMs generally don't fall below 5k rpms. 5k to the Renesis is like a brisk walk.
Old Jul 1, 2008 | 02:34 PM
fish1's Avatar
In this car I have trouble keeping it below 5K rpm's
Old Jul 1, 2008 | 05:36 PM
bejackso's Avatar
Obviously I know how a rotary engine works, just asking a simple question.
Old Jul 1, 2008 | 10:22 PM
That's BS don't listen to nygaps......
It will make your car go faster.
You will be in Zoom Zoom mode.
Old Jul 1, 2008 | 10:27 PM
this thread wouldnt even exist if you knew b4 hand.
Old Jul 1, 2008 | 10:42 PM
ChristInBen's Avatar
Correct me if I'm wrong guys, I know that the Renesis motor has no problem walking up to 9000rpm, even fuel-cutoff, however, the tranny and clutch suffer right? So, the more you shift at 9K, the more chance there is of wearing out your clutch faster, correct?
Old Jul 1, 2008 | 10:49 PM
04RX8man's Avatar
Rotary Powered Countryboy
I tend to take it to redline everyday a few times especially if the roads are wet from a redlight just let the tires spin and hold it there for about 5 seconds or so then drop it down cleans the carbon out real good...
Old Jul 1, 2008 | 10:52 PM
GAMBEAN's Avatar
bi polar rotor loner
+1
Old Jul 1, 2008 | 11:02 PM
technically, yes.
but not by much, as long as you are not dragging your clutch.
Old Jul 1, 2008 | 11:16 PM
I would listem to Nycgps!
Old Jul 1, 2008 | 11:36 PM
xsnipersgox's Avatar
One Shot One Kill
like i've said before, redline as often as you can afford to.
Old Jul 1, 2008 | 11:37 PM
one more word from you Im going to take your dog away !
Old Jul 2, 2008 | 06:44 AM
hakuna matata!
TO SUM IT UP..
7,000 is not enough.
If you're really intent on keeping the engine healthy you must -redline- it. That is WOT at 9,000+rpm for a few seconds.
Don't be scared..
Old Jul 2, 2008 | 08:39 AM
robrecht's Avatar
This age-old advice is often referred to as an Italian or Tennessee tune-up with piston engines. But rotaries, especially those with side exhaust ports and very rich AFMs, are especially prone to carbon build-up and are especially fun to red line, and high revs are safer for a rotary engine because of the rotary as opposed to reciprocal motion. And if you do wear out your clutch, just think of it as a great opportunity to install a light-weight flywheel.
Old Jul 3, 2008 | 02:25 AM
bejackso's Avatar
Dude, chill. I already specified I wasn't an expert on this subject matter.
Old Jul 3, 2008 | 07:51 AM
Bunique's Avatar
Ground Assault
Shift at 9
Old Jul 3, 2008 | 08:04 AM
Originally Posted by Bunique
Shift at 9
9 rpm ? ... thats a bit hard ...
Old Jul 3, 2008 | 08:16 AM
Bunique's Avatar
Ground Assault
OK.....when you hear the beeb. Come to think about it, I don't know if I ever hear the beeb anymore....haha just used to it I guess.
Old Jul 3, 2008 | 09:03 AM
Nubo's Avatar
Lubricious
beeb?
Old Jul 3, 2008 | 09:10 AM
Spin9k's Avatar
Momentum Keeps Me Going
my advice - live with the beep ----> zoooooooooooom......................Beeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeep shift........zoooooooooooom.............. Beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeep shift........zoooooooooooom.................Beeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeep shift.............. finish cleaning routine for the day.
Old Jul 4, 2008 | 09:33 AM
Footman's Avatar
Dodging those Corollas
I shift at 9400 rpm. Just before the fuel cutoff...
Old Jul 6, 2008 | 10:15 PM
GAMBEAN's Avatar
9? beeb? yeah just do it!
