FS: DICE I-Mazda R2 ipod integration
Old Jul 1, 2008 | 10:35 AM
preludah's Avatar
Got my dice integration kit and found out I had ordered the wrong version, so I can't use it in my car. I have the bose sound system in my car so you need the SAT button for the kit to work...
I bought it for the price of 169 $ or something, so selling it for around 140 or so... the kit is only mounted and dismounted in my car, and I will send it in the original package with the user manual and everything
Old Jul 2, 2008 | 12:19 PM
preludah's Avatar
Old Jul 5, 2008 | 08:21 AM
preludah's Avatar
Old Sep 14, 2008 | 05:49 PM
Chemicalmaul's Avatar
What is the model o the proper Dice Mod that you needed.. I am thinking of odering this unit but after reading your post and having the Bose Pkg myself... I don't want to run into the same problem.. Can you help me out?
Old Sep 15, 2008 | 06:19 AM
preludah's Avatar
I have the I-Mazda R2.... and the one you want is the R1....
Old Sep 15, 2008 | 07:50 AM
SideOfBacon's Avatar
damn.. need the ipod kit too.. but i too do not have the sat button
gl on the sale.. free bump!
Old Sep 15, 2008 | 03:51 PM
hakuna matata!
I used my Dice R2 in my car with no problems at all.. and I had the Bose system.
If you have a SAT button you should be fine...
Old Sep 15, 2008 | 06:21 PM
c41250n's Avatar
would it automatically play again once you start the car again?
Old Sep 16, 2008 | 06:40 AM
Okay... Pardon my confusion:
From my understanding I need a SAT button because I have a Bose sound Pkg.. correct
Also, just to clear things up:
First ... I need the I-Mazda R1 - if i have a Bose sound pkg??
Second... How would I know if i have a SAT button or not
Third.... Whys did alz0rz say his worked just fine but is contrary to what preludah was stating when he ran into problems.
Thanks,
Old Sep 16, 2008 | 01:11 PM
hakuna matata!
Yep.. I have a 05 with a Bose package and it worked fine. The only thing that never got to working correctly was the text with the R2 but that is completely because I never tried. The function works just the same. Having the Bose package makes no difference. You need to have a SAT button to determine if you have the the free input on the back of the radio to plug in the Dice R2.
Check your radio.. next to FM/AM, CD, etc.. should be a button that says SAT.
Old Sep 18, 2008 | 12:50 AM
Ok !!! I do not have a sat button... I have a button that says : mini disc/aux
So i guess i'm out of luck!!!
Old Apr 22, 2011 | 11:15 PM
jcruzer26's Avatar
i have a 2007 RX8 with a Bose 6 cd changer, but it also has a SAT button on it, so I am assuming I can use the R2 version, which is better b/c it displays the Artist Info, ect.
firebirdude
107
Mar 14, 2020 10:37 AM
killerfish
135
Dec 30, 2011 06:23 PM
badboysean86
Oct 19, 2011 12:57 PM
WTBRotary!
16
Sep 5, 2008 08:29 PM
Wargoose
Jun 18, 2008 05:04 PM
