Brake pad same for AT and MT?
Old Jun 30, 2008 | 03:26 AM
rx8dorifto's Avatar
hi all,
am trying to order hawk pads. but from their site, there is only 1 common part number for their pad. Is the pad similar in size for AT and MT?
Old Jun 30, 2008 | 06:29 AM
expo1's Avatar
He's as bad as Can
If you have the 18" wheels you can order them.
Old Jun 30, 2008 | 07:04 AM
BRGREEN8's Avatar
believe it or not, front pads are the exact same size and everything for the MT and base AT.
Old Jun 30, 2008 | 08:30 AM
rx8dorifto's Avatar
front is same? how about rear?
or i'll just try my luck to order as EXPO1 said that i got 18" wheel so i can order
Old Jun 30, 2008 | 08:57 AM
expo1's Avatar
He's as bad as Can
I checked a dealer site http://www.finishlineperformance.com and they showed the same part for rear pads. They did however have different front pads for RX-8's with 18" & 16" rims
Old Jun 30, 2008 | 06:48 PM
BRGREEN8's Avatar
Believe me, it uses the same pads. I had a base auto 8, used mazdaspeed pads, ebc green stuff and hawk pads. They only make one kind of pads for the front. I am more than positive that you can buy any aftermarket pads and it'd fit both manual and base auto.
Old Jun 30, 2008 | 09:31 PM
rx8dorifto's Avatar
hm...Hawk never specifies their front pad is for 18" or 16"...
should I risk it?
Old Jun 30, 2008 | 09:34 PM
rx8dorifto's Avatar
just got replied from HAWK:
"I have done some research on the braking systems in the different RX-8 cars.
From what I can find the pads are the same shapes and sizes in all of the
2007 RX-8 cars. So the FRONT - HB470F.643 and REAR - HB378F.626 are the
correct part numbers for your RX-8."
ok...i'll go ahead for the order
hufflepuff
May 30, 2016 10:45 AM
Oct 3, 2015 09:51 AM
D13
Oct 1, 2015 07:55 AM
airlive
Sep 7, 2015 08:32 PM
