Optima Battery Question?
Old Jun 26, 2008 | 10:32 PM
matt13b's Avatar
Anyone got an Optima battery in the RX8?
I was told by a battery shop that it could not fit without changing the lead arrangement and I am sure I have seen an RX8 with one since then.I want to get a dry cell battery as my battery keeps leaking when i corner hard.
Old Jun 27, 2008 | 12:44 AM
erx8s's Avatar
I have the Optima Yellow Top D51R ...R being for right hand drive cars Part number 8073-167 Fits perfectly , great strong battery no need to change any terminal wires they probably quoted you on the D5 1L for left hand drive .
http://www.optimabatteries.com.au/
Cheers
Michael
Old Jun 27, 2008 | 03:41 AM
matt13b's Avatar
Thanks,that would explain it..I'll try getting one this week.
Old Jun 27, 2008 | 06:33 AM
auzoom's Avatar
Hmmmmmm.........
I think I answered this in .com.au. As Michael said you need the R model but I haven't found anyone that stocks them, they have to be special ordered. Also they are Very heavy.
Old Jun 27, 2008 | 10:12 PM
matt13b's Avatar
Are they heavier than a stock battery? Do you have one?
Old Jun 28, 2008 | 03:13 AM
auzoom's Avatar
Hmmmmmm.........
I have the D35 (650CCA) and it weighs roughly 17kg. The D51R is only 450CCA and weighs 12kg.
The original OEM battery weighed 9.5kg and the replacement one 16.8kg. https://www.rx8club.com/rx-8-racing-25/weight-stock-rx8-parts-81791/
Old Jun 28, 2008 | 03:40 AM
matt13b's Avatar
Why did the replacement weigh so much more?
Old Jun 28, 2008 | 07:29 AM
auzoom's Avatar
Hmmmmmm.........
Because it went from a 400 odd CCA battery to a 650 to help with flooding and cold start issues.
Old Jun 28, 2008 | 07:37 PM
Revolver's Avatar
Shootin' from the hip
Knowing Matt's 'weight issues', I can almost hear the dismay in his voice on this one...
Old Jun 28, 2008 | 07:46 PM
auzoom's Avatar
Hmmmmmm.........
Yeah its kin dof why I pointed it out. Even sticking with the 450CCA you add 3kg.
Old Jun 28, 2008 | 10:25 PM
matt13b's Avatar
Well there goes that idea.You are right Dave,back to square one! I might look at that other brand that starts with O,can't think of it right now or those Pulse batteries??
Old Jun 28, 2008 | 10:57 PM
auzoom's Avatar
Hmmmmmm.........
Odyssey. But it wont help either. You either have to be carefull with cold starts, flooding etc and go for a lower CCA battery. Or suck it up and go with the heavier battery. Remembering that the battery is mainly for starting (exception is running accessories when the car isnt running). Once its running its the alternator that does all the work.
Old Jul 30, 2008 | 09:58 PM
SSA's Avatar
SSA
Boost w/meth
Wink
i have a yellow top 35. awesome, no lead changes, cranks like a motha.
Randolph Alvarez
May 30, 2016 01:08 AM
yankeepicker
Sep 11, 2015 05:42 PM
TJSiegrist
Sep 10, 2015 09:29 AM
LMURailsplitter02
Sep 6, 2015 10:56 PM
Rupanrx
Sep 4, 2015 06:44 AM
