Urgent: oil pressure
Old Jun 26, 2008 | 12:43 AM
Interpol's Avatar
Whats normal oil pressure at idle for a mt rx-8? The defi gauge is reading at 1.25kpa while the stock one is 2.5 lines past the middle on the high side.
the defi gauge has the warning light set at 1.5kpa. I'm using 10w30 RP. And the defi gauges are wired exactly as required.
Is it the car or the gauges?
Old Jun 26, 2008 | 01:13 AM
StealthTL's Avatar
Metatron
You, or your gauge, are seriously confused.
You may be happier with one calibrated in PSI.
1.25 kPa is about 2 percent of one psi.....
Perhaps you mean 1.25 thousand kPa, or 18 psi.
The stock 'gauge' is a switch, turns on around 10 psi and just stays still, don't bother waiting for it to move. Good idea to buy a real gauge.
S
Old Jun 26, 2008 | 01:27 AM
CnnmnSchnpps's Avatar
No means yes
^ actually 1.25kPa is 0.18 PSI, so it's 125kPa that would be 18PSI
agree on both other points thou
- some(one/thing) is confused
- good idea to get a real gauge
18 sounds about right at idle and you might see it go to 60ish at WOT.
maybe post a pic of the gauge? i'm assuming its digital?
Old Jun 26, 2008 | 01:30 AM
StealthTL's Avatar
Metatron
Yeah, you're right - POINT two of a psi, not 2%.....
....drunk again!
S
Old Jun 26, 2008 | 01:48 AM
Flashwing's Avatar
3-wheeler
I've seen between 18-25 PSI at idle depending on the oil temperature. I'll see as high as 70-72 PSI at WOT using 20w-50.
Old Jun 26, 2008 | 07:41 AM
Mine reads between 100 - 130kpa, depends on the oil temp, highest I've seen is about 510 kpa I think.
sometimes it dips below 100, like 90 ? that happens when idle is funky
Old Jun 26, 2008 | 04:24 PM
BMonkey's Avatar
I am pretty sure that the oil pressure rises with RPM and not throttle position. Just sayin'..........
oil pump rpm that is
Old Jun 26, 2008 | 04:39 PM
No means yes
lol mah bad. I only use WOT if i plan on going to redline anyway, so those kind of merged in my mind
RevMeHarder
Jun 1, 2026 02:30 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
tgaffner
Sep 7, 2015 08:49 PM
