Do I need new spark plugs?
Old Jun 13, 2008 | 11:24 AM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
Do I need new spark plugs? This is the plug from the rear rotor bottom plug (leading).
Old Jun 13, 2008 | 11:37 AM
it looks kinda tan to me so it should be fine.
but since u have them out ... if you have some new plugs around why not replace them ?
Old Jun 13, 2008 | 11:53 AM
I just turned the wheel and pulled this out. The rest are still in the car. And I don't have new plugs, I'm debating getting new ones. The car has 58k miles.
Old Jun 13, 2008 | 12:07 PM
when was the last time u change da plugs then ?
the plugs aint that expensive. if u're a cheapass like me, shop around and u can get all 4 for like around 70 bux
Old Jun 13, 2008 | 12:10 PM
I've never changed the plugs and I'm the first owner. They may have been changed during the slow start recall.
Old Jun 13, 2008 | 12:14 PM
That TSB/Recall had change your Leading plugs, which might be why your leading plug in photo looks pretty decent.
You might want to take one of your *trailing* plug out and look at it now.
Anyway, I suggest you to change it all.
Old Jun 13, 2008 | 12:56 PM
Old Rotor's Avatar
They look good color wise. They should be changed around 30-37K miles so you did well and will notice it when you change them. They run 50-80 bucks(ebay or sparkplugs.com) and get the OEM ones by NGK, they are the best.
Old Jun 13, 2008 | 03:55 PM
hmm, okay.... i got to find some cash then
Old Jun 13, 2008 | 04:01 PM
invasion08's Avatar
go to www.autopartswarehouse.com and get them shipped to your door for 85 dollars
Old Jun 13, 2008 | 04:14 PM
Nubo's Avatar
Lubricious
Actually they seem unusually light to me. Do a light of high-rpm/high speed driving? If not, double-check the heat range on the plugs; maybe they gave you "hot" plugs. Which may not be appropriate depending on your driving conditions.
Considerable ash deposits and the center electrode is well-rounded, suggesting these have been in service for a long time.
Old Jun 13, 2008 | 08:21 PM
Those are the best plugs I've ever seen on a RX8.
No fouling fuel. No black at all.
If he was lean they would be much lighter and yes plugs do change white when they are too lean.
Old Jun 16, 2008 | 05:20 PM
Thats what I thought razz. They looked pretty good to me...
The car has never flooded.
Old Jun 16, 2008 | 05:38 PM
brown is good
black = bad.
Rodger: you've got 50,000 + miles, don't ya? Might be time to replace them
RevMeHarder
Jun 1, 2026 02:30 PM
DylanForbes
25
Oct 31, 2017 05:47 PM
iphil
Sep 21, 2015 10:49 PM
Forevermore
Sep 20, 2015 01:04 PM
Vedivan1
Sep 18, 2015 12:39 PM
