Radio buttons don't work, steering column ones do
Old Jun 12, 2008 | 02:40 PM
importshowoff84's Avatar
Legend in the making
Well, we had to take out the radio to install my gauges, and now my display doesnt say anything, presets/volume/any buttons dont work, cant turn heat/air on. But the lights light up. I can eject/put in a cd and control the volume and everything else with the steering column controls. Any ideas of where to look/what to do? My shop that worked on the car took out the radio to double check the connections and everything is hooked up right. They can't figure it out. Do I need a new radio? It is a stock radio.
Old Jun 12, 2008 | 10:21 PM
no ideas?
Old Jun 12, 2008 | 10:36 PM
Jon316G's Avatar
Grasshopper
Did you check any fuses?
Old Jun 12, 2008 | 10:42 PM
Jon316G's Avatar
Grasshopper
Do any of the following work:
  1. cigarette lighter
  2. accessory socket
  3. ashtray light
  4. seat warmer
  5. power mirror
This might help narrow down the circuit.
Old Jun 13, 2008 | 12:16 AM
kersh4w's Avatar
Hit & Run Magnet
are the connections in the back set properly?
Old Jun 13, 2008 | 02:33 AM
fuse or something in the back of the head unit is not plugged in all the way.
or the big bad.. was the bat disconnected when the hu was unplugged?
Old Jun 13, 2008 | 02:41 AM
rx8phase1's Avatar
i have the same problems my dash starts blinking like crazy and sometimes they wont wrk but mine is because i connected my speakers to my amp so im pretty sure its some loose ground wire or something ima check it tommorrow
Old Jun 13, 2008 | 07:21 AM
  2. accessory socket
  3. ashtray light
  4. seat warmer
  5. power mirror
all work fine.....
Old Jun 13, 2008 | 07:23 AM
I believe they checked all the fuses and connections (thats what they told me) and everything is plugged in fine.
What would the battery being disconnected when hu is unplugged do?
Old Jun 13, 2008 | 08:19 PM
It's the connections.
You think it's locked into place but it isn't.
When I pulled mine out it plugged in tight.
I had to reinstall it for the same problem.
See the DIY for CD install.
Before you put it back in, let it hang doen, turn on key see if it works, I f no turn off key re-plug the connections try again.
Old Jun 13, 2008 | 09:09 PM
you could short something if the batt is still attached.. but really something is not all the way in..
Old Jun 14, 2008 | 12:20 AM
Jon316G's Avatar
Grasshopper
If all that I asked are working fine, then I would rule out a fuse or relay.
I agree with Razz and Swoope... recheck the wire harness.
ei8ht
Aug 21, 2017 09:08 AM
SIllver
Aug 1, 2015 07:34 PM
thewatcher101
Jul 27, 2015 09:44 PM
Jmanie9515
Jul 20, 2015 07:29 PM
