Tire pressure - 19" -- 40psi?
Old May 29, 2008 | 09:00 PM
heyarnold69's Avatar
Rotary wanabee
Ive been running with my 19" tires at 40 psi .. anyone recommend anything different?
Old May 29, 2008 | 10:10 PM
Charles R. Hill's Avatar
Owner of BHR
Read the side of the tire........
Old May 29, 2008 | 10:14 PM
Check tire rack.
Old May 29, 2008 | 10:29 PM
read the owners manual. then the sticker on the inside of the door. then the tire.
decide which one is likely to be the right one.
btw, the tire and the rim dont know what size they are.
Old May 30, 2008 | 01:57 AM
wassup_nuthin's Avatar
do you like traction? if not leave it at 40
Old May 30, 2008 | 10:21 PM
30
Old Jun 16, 2008 | 01:51 PM
Rotary wanabee
ive been making adjustments from 35 to 45. 40 seams to work nice and there is less sliding in wet conditions.
Old Jun 16, 2008 | 03:14 PM
if you want to die keep it at 40.
you're over inflating it by too much, even in 19in size.
Old Jun 22, 2008 | 02:42 PM
Bishop's Avatar
Attack of the Black
What should the stock 18's psi be? (the 8 is in Ontario, I'm in BC, so please refrain from telling me "check the side of the tire", thanks!)
Old Jun 22, 2008 | 02:48 PM
StealthTL's Avatar
Metatron
Wink
.......8 is in Ontario, I'm in BC.........
Unless you have a 2000 mile long airhose, it doesn't matter!
S
Old Jun 22, 2008 | 02:55 PM
MazdaJeff's Avatar
Higher pressure should give a bit more gas milage. Depends what your using the car for.
Old Jun 22, 2008 | 03:27 PM
Bishop's Avatar
Attack of the Black
S
LOL Point taken. I was just curious cuz I'm out here, my baby's out there and I just want her to know that I'm thinking of her - she checks the posts through her GPS Nav and PCM so I know she's watching.
Old Jun 22, 2008 | 03:29 PM
Spinning Sushi's Avatar
I <3 Sushi
I believe that it's 32 for stock.
Old Jun 22, 2008 | 03:30 PM
Bishop's Avatar
Attack of the Black
32? Sweet.
mysql's Avatar
Doppelgänger
32-35 is what I use
Old Jun 22, 2008 | 06:44 PM
Originally Posted by mysql
32-35 is what I use
what he said.
i run 34 on the road. works well.
Old Jun 22, 2008 | 11:12 PM
BlueRenesis82's Avatar
Registered Tracker
Dude, you know more is better. 55 PSI all the way!
Old Jun 22, 2008 | 11:19 PM
If you have 55psi, Remember to hit every single pothole u see !!!
To be named later's Avatar
Now with 25% more fluff..
Although it gives a much stiffer ride, I like to run at 75 psi. I like to compensate for the rougher ride by inflating with helium.......seems to make the car a little lighter. If the car starts getting airborne, I just attach some ankle weights to the axle. Seems to do the trick.
Old Jun 22, 2008 | 11:33 PM
NgoRX8's Avatar
i do 34 for daily driving.
Old Jul 7, 2008 | 09:28 AM
Outkast187's Avatar
40 is fine, a little less rolling resistance. 30 is mushy for my taste, 35 is a good medium. But, I do run 55-60 psi on my 13's on a 5500lb car, so maybe Im not the one to ask....lol.
Old Jul 7, 2008 | 09:57 AM
Jax_RX8's Avatar
Got Another Rotary
Another thing to consider is your camber settings. If you have lowering springs (which creates more camber) or just have more dialed into you alignment, you should consider running less Air pressure - around 30-32 psi max if you want any tire life at all. Higher pressure will not allow to tire to "sit down" on the rest of the tire and will burn up the inside edges much faster than when running lower pressures.
Old Jul 13, 2008 | 12:56 AM
RenesisX-8's Avatar
Non-average GearHead MoFo
actually, from my own experinces, running lower pressure makes the outer treads wear more in street applications. running more pressure makes the middle wear more. running the right amount of camber and 30-35psi cold seemes to help tire wear and provide a good ride. inflate to 35-40 if you are getting outer tread wear, or are in colder climates. I dont know if you would gain any fuel mileage by over-inflating your tires... alignment would have the greatest effect on that.
On 19's I would want to run in the lower 30's range to give a little more cushion between the rim and the road surface.
Old Jul 13, 2008 | 01:15 AM
the one time size does not matter!
Old Jul 13, 2008 | 11:36 AM
Jax_RX8's Avatar
Got Another Rotary
You are absolutely right for a normal alignment.
But you missed my point - when you lower your car via lowering springs or have added more camber into your alignment on purpose to support better cornering, this does cause more inside tire wear independent of pressure.
I am just stating that lowering the pressure some will allow the tire to sit down on the rest of the tread (not just the inside) to make the wear a little more even. This will cause more total grip as well, but may increase rolling resistance some (but unlikely to effect gas mileage much)
Just something to consider.
cliffkemp
Dec 24, 2024 10:48 AM
hufflepuff
May 30, 2016 10:45 AM
snowrydr01
Nov 23, 2015 09:40 AM
