Radio Trouble After Install
Old May 23, 2008 | 07:38 PM
bpresley09's Avatar
New Owner
Hi guys,
I recently finished running the wiring for my system I've been working on.
Today, I hooked up the power wire & fuse holder to battery. After that, my radio display & ac controls stopped functioning. Both cigarette lighters and also my power mirrors stopped working also. All help is appreciated!
Focus: How do I regain power to radio,, lighters, mirrors & ac controls?
Old May 23, 2008 | 08:14 PM
DeViLbOi's Avatar
The devil made me do it
Disconnect the amp and replace the fuse for the radio.
Old May 23, 2008 | 08:17 PM
Socket7's Avatar
ಠ_ಠ
Check every single cable for a short or incorrect connection before you reconnect your amps. Sounds like you have a wire crossed and it popped the fuse for the head unit.
Old May 23, 2008 | 08:24 PM
bpresley09's Avatar
New Owner
I've already checked the fuse labeled "audio system" and it's fine.
The amp is not hooked up, the power wire is in the trunk disconnected.
Old May 23, 2008 | 10:42 PM
WikkedOne's Avatar
Deals on wheels
check ALL the fuses... sounds like an acc fuse or something.. and find the short that caused it.
Old May 25, 2008 | 01:02 PM
AmKorp's Avatar
if you've got the power wire just sitting in the trunk, it may have touched something back there that caused the short. Make sure you wire up power wire or have it capped off so it doesn't touch random things and short.
Old May 28, 2008 | 09:44 AM
Thack's Avatar
fuses labeled "radio" in cars are only for accessary. you have a constant that is probobably connect with something else that supplies power. like wicked said check ALL your fuses.
Old May 31, 2008 | 01:53 AM
Originally Posted by LRKSFAG
Brother's great, I top youSKF***NSKTIMKEN
hey learksfag,
**** off. reported.
JimmyBlack
273
Feb 10, 2020 10:23 PM
CMRine04
Sep 23, 2015 09:31 AM
just1jack
Sep 9, 2015 04:45 PM
