KC_RX-8
11-15-2003, 05:35 PM
I have just installed aftermarket 18's on my stock tires and the TPMS light has cam on. I have tried to do what the manual says but no luck. Any other suggestions?
View Full Version : TPMS light on KC_RX-8 11-15-2003, 05:35 PM I have just installed aftermarket 18's on my stock tires and the TPMS light has cam on. I have tried to do what the manual says but no luck. Any other suggestions? mikeb 11-15-2003, 05:53 PM sorry, cant help there but how about some pics of those enkei's OUR X 8 11-15-2003, 07:25 PM Did you install the sending units on your new wheels? KC_RX-8 11-15-2003, 07:32 PM Originally posted by OUR X 8 Did you install the sending units on your new wheels? Yes OUR X 8 11-15-2003, 07:40 PM hmmm....... KC_RX-8 11-16-2003, 09:30 AM so i guess no one has got any advice for me? rx8cited 11-16-2003, 11:03 AM Hi KC_RX-8, so i guess no one has got any advice for me? I've got some :) ........ if the TPMS warning light is flashing, then try the following: Look at "Tire Pressure Monitoring System Service Tips" http://www.finishlineperformance.com/rx8/docs/02-002-03.html Assuming you do have the TPMS wheel units (sensors) installed on all wheels, you should just have to do step 3 "Perform Wheel Unit Auto Registration" under the "Replacing a TPMS wheel unit" section (bottom of document - or http://www.finishlineperformance.com/rx8/docs/02-002-03-5.gif ) . Just curious, which wheels and sensors (Mazda?) are you using ? Let us know if the above fixes the problem. Good luck, rx8cited CraziFuzzy 11-16-2003, 11:23 AM Is the light on or flashing? if it is steady on, it means it is seeing the pressure as too low or too high. If it is flashing, that means it is seeing a problem with the sensors, and probably doesn't recognize them. What pressure do you have the tires inflated to? KC_RX-8 11-16-2003, 07:22 PM the light is just on, not flashing. XeRo 11-17-2003, 11:07 AM pump those suckas up!...or let some air out....either one of these should set you straight,.,.i think someone stated that already...oh well.. KC_RX-8 11-18-2003, 12:44 PM Originally posted by XeRo pump those suckas up!...or let some air out....either one of these should set you straight,.,.i think someone stated that already...oh well.. HAHAHAHA!!! thanks XeRo!! that was it, too much air!!! no more light!! |
