Whining noise on idle...please help
Old Apr 22, 2008 | 12:33 PM
CrowBoy66's Avatar
Hey Guys I was at a drive through and noticed that my car makes a high pitched whining noise while I'm in neutral. If I give it gas the whining goes away. I'm thinking it might be a belt that needs to be lubed. Anyone else have this issue. I did a search but didn't come up with anything. Thanks in advance!
Old Apr 22, 2008 | 12:41 PM
Detrich's Avatar
幹他媽!
is it more a high pitched whistle/ hum or an actual "noise" that sounds like something is rubbing?
high pitched whining is signature of the renesis engine. all of our cars do that on idle. just search the forum for discussions and you'll see.
Old Apr 22, 2008 | 03:34 PM
CrowBoy66's Avatar
well it's more like a squeeking noise...i know the rotary's have a different noise at idle, but this is a new noise.
Old Apr 22, 2008 | 03:37 PM
Cattywampus's Avatar
Turbos blow!!
Check belts with the car running and the hood open. Listen to see where the noise is coming from.
Old Apr 22, 2008 | 05:17 PM
Go48's Avatar
Does the noise go away when you press on the clutch? If it does, it is normal and most likely the tranny mainshaft rotating on ball? bearings. When the clutch is engaged (i.e., pedal out) the shaft rotates, and when the clutch is disengaged (pedal depressed) the shaft does not rotate. The noise might have been there all along but the sound reflection from the building wall may have made it more noticable.
Old Apr 23, 2008 | 07:11 PM
Transam kid 01's Avatar
The anti-ricer
You mean transmission gear roll over noise?
I have that high pitched chirping noise from my car...it's actually very loud and very unappealing. It hasn't always been there though...know of any fixes?
Old Apr 23, 2008 | 09:39 PM
Fullthrottle's Avatar
do you an automatic or manual if its a manual might be the throw out bearing if you push the clutch in does it go away ? if yes its the throw out bearing
Old Apr 23, 2008 | 11:16 PM
The anti-ricer
Manual of course
It goes away when I even slightly depress the clutch...not even engaging it.
Old Apr 23, 2008 | 11:19 PM
Rootski's Avatar
DGAF
It's probably just gear chatter then, and it's nothing to worry about.
Old Apr 24, 2008 | 03:37 AM
search gear rollover.
Mane
Nov 20, 2015 12:16 PM
nowakm99
Oct 9, 2015 07:10 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
neoksk
Sep 21, 2015 12:31 PM
