'09 RX-8 In-Depth Changes
Old Apr 21, 2008 | 11:09 PM
teknics's Avatar
Certified Mazda Tech
not sure if this has been posted up, and if it has been i apologize, but I figured I'd throw it up here for you guys:
ENGINE FEATURES [13B-MSP]
On-board Diagnostic
To meet OBD-II regulations - Diagnostic test modes changed
Improved serviceability - DTCs changed, KOEO/KOER self-test function changed, PID/DATA monitor function changed, Simulation test function changed
Mechanical
Reduced engine noise and vibration - Stationary gear changed (standard power)
Improved engine torque - Auxiliary port adopted (standard power)
Lubrication
Improved lubricity - An electric type metering oil pump system adopted , Center oil nozzles adopted which discharge oil to the center area of the rotor
housings, Oil pump changed, Oil pan upper block adopted
Improved serviceability - Oil filter position changed
Cooling System
Improved cooling performance - Radiator changed, Water pump changed , Cooling fan component changed
Charging System
Improved generator output - Generator changed
Cruise Control System
Improved driveability - Cruise control switch changed
Control System
Improved engine torque and output - S-DAIS control changed, APV position sensor No.1, No.2 adopted
Improved engine reliability - KS No.1, No.2 adopted, Electrical fan control changed, Fuel injection control changed
Improved lubricity - Metering oil pump control changed Metering oil pump driver adopted, Oil pressure control adopted Oil pressure sensor adopted
Also noticed in the papers I have that oil pressure is way up. I'll have some more stuff tomorrow, I just received the new workshop manual for it so I'll see what I run into of interest. Oh and also of notice is the alternator no longer has a voltage regulator, the PCM controls the alternator completely now.
Kevin.
Old Apr 21, 2008 | 11:56 PM
hakuna matata!
sweet thanks kev
Old Apr 22, 2008 | 12:03 AM
LionZoo's Avatar
road warrior
Wow, great stuff!
Old Apr 22, 2008 | 12:45 AM
So they will *Finally* have a working oil pressure sensor instead of a dummy Gauge ?
wow .... at last
What kind of radiator change they have I wonder ... hmm
Oh Thx for the info Kevin !
I know the engine cannot be change ...
Old Apr 22, 2008 | 12:57 AM
gundarx's Avatar
Hummmmm...
neat info.. thanks
Old Apr 22, 2008 | 02:08 AM
keep up all the great info kev.
Old Apr 22, 2008 | 03:29 AM
sosonic's Avatar
It is really sad that all these really great engine improvements are overshadowed by that ugly plastic grille on the new models.
From the looks of it, if you blow the old engine type, putting in a new one should make you feel better. Interestingly, with the improved engine and changes, I would think the RX-8 would get that claimed 232HP and maybe 240HP much more consistently.
I wonder which of these new parts can go into the old RX-8?
For example can you put the improved water pump, radiator, cooling fan, or new oil pressure sensor into the old RX-8?
Old Apr 22, 2008 | 01:39 PM
My radiator should be fine. Hmm I wonder what kind of *new cooling fan* they have. probably changing the fan blades or shape, could probably bolt on since all RX-8 has same frame.
oil pressure sensor I'll pass, I already have one but its always good if it comes @ stock ...
I have been thinking the alternator is too small for this car. 100amp MAX. blah, I think the most you can get out of that thing is around 90~ish or 90 AMP. Maybe thats why FEED has a replacement of 130AMP. Hmm Can this bolt on to our car now ? control by the PCM huh ... I doubt it then.
BillBertelli
NE For Sale/Wanted
Mar 19, 2016 03:01 PM
Brokegang
Jan 3, 2016 12:45 PM
arexatemate
Oct 9, 2015 06:23 PM
Chapsy
Sep 22, 2015 09:57 AM
Tsurugi
Sep 7, 2015 08:27 PM
